CALIFORNIA KING PLATFORM BED
Introduction: CALIFORNIA KING PLATFORM BED
About: In my shop I have a name for hammer, saw, and plier. The saw is Tess, the hammer's Joe, and Glumdalclitch is the plier. Yes, I'm brillig, and my slithy toves still gyre and gimble in the wabe. With that, le…
My daughter-in-law asked if I could make her and my son a California King bed frame with lots of storage. I said, "Sure,"
Step 1: PLANS FOR a CALIFORNIA KING BED
PLATFORM BED PLANS FROM STEVE RAMSEY'S WWMM
I've been a fan of Steve Ramsey for years. He makes things easy to follow. I downloaded his plans and followed them.
The plans list all materials along with a cut chart.
IMPORTANT: DOUBLE CHECK ALL YOUR MEASUREMENTS. WOOD THICKNESSES VARY. USE JIGS AND STOPS TO GET VERY ACCURATE CUTS AND SPACING. I CANNOT STRESS THIS ENOUGH.
Step 2: TOOLS
Here are the tools needed to complete this project.
Miter saw
Pocket hole jig and bits
Screw gun and various screws
Compressor and nail gun
Mallet
Orbital sander
Router Table
Clamps
Glue
Stain using rags and brushes
Polyurethane
Step 3: I WORKED IN SECTIONS
I worked in sections, doing the exterior frames for each box first. I cut the pieces to size.
Step 4: I ASSEMBLED THE TWO BOX FRAMES
Using my assembly table and pocket hole jig and lots of pocket screws I assembled the two box frames.
Step 5: DRAWER RUNNERS AND GUIDES
As I assembled the sections I made jigs to help align the runners and guides. I spent extra time studying the plans and labeling pieces. Where I didn't use pocket screws I used my brad nailer to hold boards in place while the glue set.
Step 6: STAINING
Once the two mirror image frames were completed I coated the wood with pre-stain then stained it. When that had thoroughly dried I gave it a coat of poly. Sanded when dry and added a second coat.
Step 7: DRAWERS
The plans for the drawer construction use 3/4" plywood. I used 1/2" plywood. I used 1/4" masonite for the drawer bottoms. I've used masonite before on other projects calling for a drawer bottom. It makes a really nice, smooth interior.
Here is where I ignored the cut guide and measured each piece myself. I assembled each drawer using glue and brads. I rabbeted the bottom of each drawer for the masonite to fit flush to the bottom. I double and triple checked for square.
I applied paste wax to both the bottom of the drawers and the guides they slide on. There are a total of 6 drawers.
Step 8: DRAWER FACES
The drawer faces in the plans called for ripping down 1 x 10s to 8". I didn't. I left them at 9 1/4. No knobs were used since they stick out too far and someone could hurt themselves. Instead, I routed a finger pull on the edges, even on the fixed drawer faces. I experimented with a round over bit for a finger pull and a cove bit, too. The one I settled on was a rabbet. Then I stained and polyed them, sanding up to 320 grit between coats.
Step 9: THE PARTS
Two box frames. Six drawers. There are actually spots for two more drawers where the end tables are at the head of the bed. I can always add these if they become necessary. I didn't make any dummy drawer faces for the back of the bed. This will be against the wall and not visible. Also, I might be building a headboard if my kids want it.
Step 10: ATTACHING THE DRAWER FACES
To ensure even spacing I made some spacers, held the drawer faces up to the spacers and secured with brads to hold the faces in place and screws to secure them. I set the drawers aside. You can see the false drawer faces on the box frames.
Step 11: MATTRESS SUPPORT
I made the mattress support from 1/2" plywood. Yes, I did cut another piece.
Step 12: YOU GOT TO MOVE IT, MOVE IT...
My son and daughter-in-law live twenty-five minutes away. We loaded the plywood and box sections into a borrowed truck. I loaded the drawers into my SUV. We all drove to their home. Then we carried the parts up three flights of stairs into their bedroom. I screwed the two frames together and we put on the mattress and slid in the drawers and it was done.
As usual, all comments appreciated and all questions answered. Thanks for taking the time to view this Instructable brought to you by The Little Shop of Jarfold.
Kink Jarfold
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    2 Discussions
    ELamp1268
    ELamp1268
    Question 8 months ago
    I can not seem to download this project, any help would be great. Thank you
