Introduction: CHANGE CINCINNATI MILACRON SABRE O ARROW 500 HDD ACRAMATIC 2100 VICKERS
About: DESING AND MANUFACTURING SOFTWARE AUTOCAD,MASTERCAM,INVENTOR PROFESIONAL,RHINOCEROS, FUSION 360, REVIT, CNC, MAQUINAS HERRAMIENTAS, REPAIR CNC CINCINNATI Y FAGOR :p
CHANGE CINCINNATI MILACRON SABRE 500 HDD ACRAMATIC 2100 VICKERS
si tu error es una pantalla azul con muchas letras que es error de inicio O cualquier pantalla azul, mándame una imagen ghost o acroNis y con tu numero de parte y modelo de maquina y con gusto te restablesco tu disco para repararla
if your error is a blue screen with many letters is startup error send me a ghost or acronis image and your article number and machine model to my mail
Step 1: 1.-remove the Hdd From the Cnc to Check and Copy
remove the hdd from the cnc to check and copy
discs have the following parts number
extraer el hdd de el cnc para poder verificarlo y copiarlo
tengo los discos con las siguientes numero partes
la sabre 500 np: 3-424-2383A
ARROW 1000 ERO -MAI: BV980608 (91203412G) NCX: MV980408 (7-000-5664) SYSTEM: SY980408 (7-000-5667)
HAWK 250 MAI: BT990726 (91203658) NCX: MT981216 (7-000-5663) SYSTEM: SY981117 (7-000-5667)
ARROW 500 ERO B N. P: 3-424-2174-A02
ARROW 500 ERO
ARROW 1000 ERO B (PARAMETERS) MAI: BV980608 (91203412G) NCX: MV980408 (7-000-5664) SYSTEM: SY980408 (7-000-5667)
ARROW 500 (PARAMETERS) MAI: BV960711 NCX: NV960628 SYSTEM: SY960628
ARROW 500: (PARAMETERS) MAI: BV961119 NCX: MV961211 SYSTEM: SY961017
hawk 200: MAI: CV981217 (7-000-5789) NCX: MV981217 (7-000-5795) SYSTEM: SY981217 (7-000-5800
CON CONTROL ACRAMATIC 2100 VIKERS :)
Step 2: 2.-connect It As a Slave in Computer Equipment to Recover or to Back the Substitute
connect it in computer equipment to recover or to back the substitute
conectalo en un equipo de computo con windows para poder recuperarlo o realizar la copia al sustituto
Step 3: 3.-norton Ghost Running the Application and Performs the Image of the Unit or If You Have and Install It on the New Disk Image
ejecuta la aplicación norton ghost desde windows XP y realiza la imagen de la unidad o si se tiene ya la imagen instalara en el nuevo disco. debes de conectar en una maquina similar a el control de el cnc de lo contrario se bloquea
norton ghost running the application and performs the image of the unit or if you have and install it on the new disk image
Step 4: 4.-install Disk in the Machine and Make Sure the Software Runs Correctly
instala el disco en la maquina y comprueba que se ejecuta el software correctamente
install disk in the machine and make sure the software runs correctly
Step 5: 5.-once I Run the Upgrade From the Hdd Put It in a Box to Avoid Any Short Circuit With the Metal
once I run the upgrade from the hdd put it in a box to avoid any short circuit with the metal
una vez que funciono la actualizacion de el hdd ponlo en una caja para evitar algun corto circuito con el metal
SUSCRIBETE A MI CANAL PARA MAS REPARACIONES
https://www.youtube.com/channel/UCc1ul_ItPgHWpKHnEBYEyGg
visita mi sitio web para descargar el softwareCNC
http://twineer.com/51xE
:P
DOWNLOAD SOFTWARE image hdd
SABRE 500
ARROW 500 ERO
ARROW 500 ERO B
ARROW 1000 MAI: BV980608 (91203412G) NCX: MV980408 (7-000-5664) SYSTEM: SY980408 (7-000-5667)
HAWK 250 ERD BASE SYSTEM (SY981117) P/N: 7-000-5667 NC EXTENSION (MT981216) P/N 7-000-5663 P/N 91203658 (BT990726)
123D Circuits Contest
