Introduction: CLOCK USING ATMEGA 8
ATMEGA 8 is one of the cheapest micro controller ,so i decided to make clock using it.The first thing i came across is displaying time hence most general thing is 7 segment display but i can't display all the text expect few ,so i decided to go with 16X2 LCD .Then i came time keeping where recent most of the micro controller offer internal RTC(Real Time Clock) but ATMEGA 8 we don't have internal RTC so i went with external one.Then i came across power the clock ,atmega can run from 1.8v to 5v so i planned to 1s lipo,it worked pretty well...so let start building
Step 1: Components List
- Atmega 8 ic
- 16X2 LCD display
- DS3231 RTC module
- 1S lipo battery
- TP4056 lipo charger module
- drilled PCB
- 16MHZ crystall oscillator
- 22pf capacitor
- 10K resistor
Step 2: Burning Boot Loader on ATMEGA 8
- Simplest method is remove the ATMEGA 328 from arduino uno and insert the ATMEGA 8 in it.
- Connect the SPI pins with another Arduino uno and and burn the boot loader
- follow this video for better under standing
Step 3: Connecting RTC to Arduino
- Connect SCL pin of RTC to A5 arduino
- Connect SDA pin of RTC to A4 arduino
- Connect VCC pin of RTC to 5v arduino
- Connect GND pin of RTC to GND arduino
Step 4: Uploading Time to RTC
- Download the clock program
- open the code
- uncomment the following line
- fix the current time
- uplode the code
- now the time is saved to RTC
- now comment back the lines and upload it again
- now remove the ATMEGA 8 from the arduino
- https://drive.google.com/file/d/1yI7EckZE8ESWeCIQO...
- check out this link for more information
Step 5: Building the Circuit
- Start by soldering the ATMEGA 8 to pcb
- Then make the oscillator circuit for the ATMEGA 8
- Refer the atmega 8 pinout
- Then fix the RTC and LCD module
- Make the connection according to the circuit diagram
- Fix the lipo Battery and its charger
Step 6: Creating a Outer Case
- I don't have 3d printer so i decide to make it using cardboard and covered it using colored duct tape
- It look shiny and beautiful
- I will recommend to build a 3d printed case to look more professional
Step 7: Functions of Clock
- It is in 12hrs format ,so it will display the AM/PM
- It will display the time with seconds
- It will show the day and date in every two mins
- It will show the room temperature in every two mins
- It has the battery backup ,so even when there is no power it will run on its battery
- RTC has its own battery ,so even if the battery backup dead the time won't get rest.
- I hope u will like this project ....!!! Consider subscribing to my YouTube channel !!! Happy Learning.
Clocks Contest
