CONTROL LED MATRIX MAX7219 WITH ARDUINO
Introduction: CONTROL LED MATRIX MAX7219 WITH ARDUINO
About: Arduino fan!
In this tutorial we will learn how to control the MAX7219 Led matrix with Arduino by displaying a simple text.
Watch a demonstration video.
Teacher Notes
Step 1: What You Will Need
  1. Arduino UNO (or any other Arduino)
  2. LED MATRIX. We are going to use the FC-16 module which has four casacaded 8×8 LED Matrix Displays and a built-in MAX7219 LED Driver for each display.
  3. Jumper wires
  4. Visuino program: Download Visuino
Step 2: The Circuit
  1. Connect LED Matrix pin[VCC] to Arduino pin[5V]
  2. Connect LED Matrix pin[GND] to Arduino pin[GND]
  3. Connect LED Matrix pin[DIN] to Arduino digital pin[11]
  4. Connect LED Matrix pin[CS] to Arduino digital pin[10]
  5. Connect LED Matrix pin[CLK] to Arduino digital pin[13]
Note: Read also the part for Troubleshooting below
Step 3: Start Visuino, and Select the Arduino UNO Board Type
To start programming the Arduino, you will need to have the Arduino IDE installed from here: https://www.arduino.cc/.
Please be aware that there are some critical bugs in Arduino IDE 1.6.6. Make sure that you install 1.6.7 or higher, otherwise this Instructable will not work! If you have not done follow the steps in this Instructable to setup the Arduino IDE to program Arduino UNO! The Visuino: https://www.visuino.eu also needs to be installed. Start Visuino as shown in the first picture Click on the "Tools" button on the Arduino component (Picture 1) in Visuino When the dialog appears, select "Arduino UNO" as shown on Picture 2
Step 4: In Visuino Add Components
  1. Add "Clock Generator" component
  2. Add "Text Value" component
  3. Add "Counter" component
  4. Add "Integer Multi Source"
  5. Add "Maxim LED Display Controller SPI MAX7219/MAX7221" component
Step 5: In Visuino Set Components
  1. Select "ClockGenerator1" and in the properties window set "Frequency" to: 5
  2. Select "Counter1" and in the properties window set Max>Value to 0 and Min>Value to -170
    Note: -170 is the distance on X (length of the text), that the text will travel from left to the right, you can play with this number to get the right length
  3. Select "IntegerMultiSource1" and in the properties window set "Output Pins" to: 3
  4. Select "TextValue1" and set the "Value" (This is the text you want to display on the LED Matrix): ARDUINO LED MATRIX PROJECT
    1. Select "LedController1" and in the properties window select "Pixel Groups" and click on the 3 dots.
      In the "PixelGroups" window drag "2D Graphics" from right side to the left side
      Select "2D Graphics1" on the left side and in the properties window set :
      - "Height" to 8
      - "Mirror Horizontal" to true
      - "Orientation" to goUp
      - "Reverse Horizontal" to True
      - "Reverse Vertical" to False
      - "Width" to 32
      - Select "Elements" and click on the 3dots
      In the "Elements" window drag "Fill Screen" to the left, expand "Text" and drag "Text Field" to the left side.
      Select "Text Field1" and in the properties window set "Wrap" to False, Select "X" and click on the "Pin" icon and select "Integer SinkPin" <<see the picture
      Close All windows
    2. Select "LedController1" and in the properties window set "Intensity" to 0.1 <
    Step 6: In Visuino Connect Components
    1. Connect "ClockGenerator1" pin [Out] to "Counter1" pin[In]
    2. Connect "Counter1" pin [Out] to IntegerMultiSource1 pin [In]
    3. Connect "IntegerMultiSource1" pin[0] to "LedController1" > Text Field1 > X
    4. Connect "IntegerMultiSource1" pin[1] to "LedController1" > Fill Screen1 > Clock
    5. Connect "IntegerMultiSource1" pin[2] to "TextValue1" pin [Clock]
    6. Connect "TextValue1" pin[Out] to "LedController1" > Text Field1 > In
    7. Connect "LedController1" pin [Chip Select] to Arduino digital pin[10]
    8. Connect "LedController1" pin [Out SPI] to Arduino pin[SPI In]
    Step 7: Generate, Compile, and Upload the Arduino Code
    In Visuino, Press F9 or click on the button shown on Picture 1 to generate the Arduino code, and open the Arduino IDE
    In the Arduino IDE, click on the Upload button, to compile and upload the code (Picture 2)
    Step 8: Play
    If you power the Arduino UNO module, the LED Matrix will start to Display the text from left side to the right side.
    Congratulations! You have completed your project with Visuino. Also attached is the Visuino project, that I created for this Instructable, you can download it here and open it in Visuino: https://www.visuino.eu
    Step 9: Troubleshooting
    In my case When powering the Arduino the LED Matrix was blinking and the Text was not fully displayed. The reason for this was because MAX7219 chip is very sensitive to any voltage interference.
    To solve that I added a 47uf electrolytic capacitor between the LED Matrix VCC(+) and GND(-), make sure you connect the capacitor right, + on (VCC) and - on the (GND)
    Be the First to Share
      • Magnets Challenge
        Magnets Challenge
      • Raspberry Pi Contest 2020
      • Wearables Contest
        Wearables Contest
