CRACK a Coconut Without Tools
I hate trying to hit a coconut with a hammer. We’ve all tried and it slips off. Grrrrrrrrr. Then you try throwing it in the Air hoping that it breaks when he hits the ground. But here is a technique put it into those grocery bags that you have way too many of then hit it against the ground or on Rock. Works like a champ. You can also tell if the coconut is bad just by tasting the milk. This coconut is definitely bad, but you’ll get the concept of how to open it.
Teacher Notes
Step 1: Coconut Water
Use a drill bit to drill two holes into the coconut then drain it into a cup. Taste the water to see if the coconut is bad, in our case the coconut is bad.
Step 2: Cracking It
Put the coconut in two bags and swing it at a rock and it should break no problem!
Step 3: Finished
Now you can enjoy your coconut that you opened with out any tools!! :)
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
