CUP TOP AIR CONDITIONER
10,781
87
12
Introduction: CUP TOP AIR CONDITIONER
I've seen a number of DIY AC units using a Styrofoam cooler, fan and ice. After many years of sweating in the sun watching youth sports, I thought it would be nice to downsize and personalize the concept. So this is for all the dutiful parents supporting their kids - soccer, baseball, swimming, camping, etc. It's not going to blow your hair back, but it's a pleasant, portable cool breeze. STL files included (step 5). Good luck.
Step 1: BASE TUMBLER
For this project I purchased an Ozark tumbler (Walmart - approx. $8)
Interior of cup mouth is 3 11/16" (seems to be a common size)
Step 2: DRILL
To more easily remove the center of the lid for air flow, drill holes around the inner surface as a guide
Step 3: SAW
Connect the holes with a jigsaw to completely remove the center
Step 4: EDGE CLEAN-UP
Clean up the rough edge with a stone grinding tool and light sand paper
Step 5: 3D DESIGN (download)
Using the 3D software of your choice (3DS Max pictured), create the objects needed based on the specs of the tumbler used - fan blades, spout, fan grill and a surface to hold it all together
STL files available for download
Notes:
1) The bottom of the base surface should be flat as it will be attached to the lid for an air tight fit to the tumbler
2) You'll want the fan blades as close as possible to the sides of the intake tube but allow for the shell thickness during printing
3) You'll also want the fan blades positioned well within the tube to get a better draw
4) Mind the ON/OFF switch when creating placement for the battery pack
Step 6: 3D PRINT
Print individual objects (in this case I used a DaVinci miniMaker)
Step 7: ADDITIONAL PARTS
Additional parts needed - 3V motor and AA battery pack (ON/OFF switch included on pack)
Notes:
The motor used was listed on Amazon as: Flormoon DC Motor Mini Electric Motor 3V 8500RPM
With version 2.0, I will probably place/wire a larger, separate ON/OFF switch in the space to the left of the spout
Step 8: MOTOR PLACEMENT
Epoxy the motor into position
Step 9: FAN BLADE
Epoxy the fan blades onto the motor post making sure that the rotation and tilt of the blades will force the air down, into the tumbler (I ran the motor before the epoxy dried to make sure the placement was level)
Step 10: SUPER GLUE SPOUT
Super Glue spout into position
Step 11: ADD FAN GRILL/BATTERY PACK
Super Glue the fan grill and epoxy the back plate of the battery pack into position
Notes:
Make sure epoxy is dry before you replace the cover to the battery pack
Step 12: SOLDER WIRING
Solder wires - red to red, black to black (heat shrink protection optional)
Step 13: ATTACH TO LID
Epoxy the completed unit to the tumbler's lid
Step 14: ADD ICE
Fill 2/3rds of the tumbler with ice
Step 15: ENJOY
Step 16: NOTES:
1) The mouth seems to be the same size as other popular tumblers as well as a number of commercially used cups, so this unit should be able to fit on top of that ice cold Coke while on the go.
2) I do NOT recommend drinking from the spout - the motor and wiring are not protected or waterproof so tipping the cup to drink is probably not the best course. However, the spout I designed is angled such that a straw can fit down through the space.
3) Yes, this version is a bit clunky (more of a proof of concept). I'll be working on something more aesthetic for version 2.0. Thanks for checking it out.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    12 Discussions
    OnlyForever88
    OnlyForever88
    1 year ago
    Hello friend! I love your attention to detail on your design. If I could make a suggestion, i have seen other designs work better by making a tube with holes all the way to the bottom to direct the air flow to be pushed back up through the ice, a man on youtube does this concept on a cooler and proves the efficiency of it and ryobi has a cooler for sale that uses this concept as well. Summer is upon us, stay cool!
    DexterL3
    DexterL3
    2 years ago
    what the size for DC Motor ?
    3D-NM8OR
    3D-NM8OR
    Reply 2 years ago
    I'll make this notation adjustment in step 7 - thank you.
    StefanE15
    StefanE15
    2 years ago on Step 16
    For drinking the content, why don't you just add a small hole for a straw to go through? Maybe even add a pin of some sort to plug in, while not using the straw hole.
    3D-NM8OR
    3D-NM8OR
    Reply 2 years ago
    A good thought, and I had thought about a straw hole, but went with angling the spout to accommodate a straw. I was trying to keep it minimal. As you mention, it adds another level of rubber plug and then how do you attach the plug when you're using a straw, etc. I was also looking ahead to version 2.0 when I'd be using the space on the left (where a straw hole would fit nicely) for a larger ON/OFF switch.
    Post pics if you happen to make the adjustment - would love to see folks variations (and improvements) - ty
    3D-NM8OR
    3D-NM8OR
    2 years ago
    For those asking -
    1) I've swapped out the .max files for download in step 5 to .stl files.
    2) The motor used was listed on Amazon as: Flormoon DC Motor Mini Electric Motor 3V 8500RPM
    Thanks again for the interest.
    Quester-59
    Quester-59
    Great ideas deserve another,
    If you don't have a printer, you can purchase Squrell cage fans at amazon s 5 for 10.00 $.
    ttyp00
    ttyp00
    Question 2 years ago on Step 7
    Do you have a source and/or partnumber for the motor that fits your MAX design?
    Super great little design BTW
    jim_lewis1
    jim_lewis1
    2 years ago
    HI, nice project and use of the printer. When I saw the project idea I thought you were going to blow the air through a wetted material to achieve cooling. Evaporative cooling. I think you may find this more effective than over the ice. Although then you probably won't want to drink the contents.
    3D-NM8OR
    3D-NM8OR
    Reply 2 years ago
    Agreed - evaporative is more effective, but on this small of a scale I don't know that there would be enough of a difference to offset the more complex system, slightly larger motor/power source and tighter spec tolerances to push air through a material and still have enough air flow on the back end. My intent was to simply downsize the Styrofoam cooler concept so that it was functional yet flexible enough to work on multiple cup/tumbler form-factors and still maintain the ability to drink the contents.
    Would love to see a sketch of what you had in mind.
    Thanks
    littleredbeetle
    littleredbeetle
    This is a Cool (pun intended) build. I would love to build one for myself, but I don't have access to 3DS Max. Is there any way you would be willing to upload a .stl version, or even like a .dwg or something might get me there (or a thingiverse link or something). Quality instructions otherwise. I look forward to seeing more from you.
    rthompson825
    rthompson825
    Do you have the 3D print files available?
