Introduction: CanardWings - a Variation of Paperang, a Cool Paperplane/glider
This is a variation of the famous Paperang. I found the Paperang works, but does not fly as well despite tweaking the trailing edge.
I began to explore to see if I can somehow create a pair of canards or stabilizers at the nose since the wings are aerodynamically shaped.
After several attempts...the CanardWings was born....
Step 1: You Need a Sheet of A4 Paper 70~80gm
First print out this trailing edge curvature for the wings.
You may also want to experiment with different curvatures.
After printing, cut along the curve line, set it aside. It will be used for tracing onto the actual glider.
Print this
Step 2: The Fold...
Use a fresh sheet of A4 paper, place it on a table with the long side towards yourself.
Fold in half, aligning the edges as accurately as possible. Crease the fold.
Fold paper in half
Step 3: Paper Folded in Half
Bring point (A) to the folded edge, forming a triangular flap.
forming the first flap
Step 4: Triangular Flap Formed
Crease the fold and repeat on other side, then flip over.Folded triangle flap
Step 5: Next Fold...
Fold up (B) to meet the angled edge.
Fold up (B)
Step 6: Fold Up (C)
Next fold point (C) up to meet the edge.
Fold up (C)
Step 7: Make a Cut in the Folded Center
Cut the folded center according to the photo below, use a sharp razor for a neat cut:
Step 8: Center Fold Cut...
Cut from the top of triangle...
Center fold cut
Step 9: Fold Down Along Center Cut...
Fold down the flap made possible by the cut center fold.
Repeat fold on other side and flip over again.
Fold down along cut center
Step 10: Both Sides Done...
This photo shows both sides folded down...ready to trace the printed curvature on the trailing edge and cut the curve.
Both side folded down
Step 11: Trace and Cut the Curved Trailing Edge.
Now take the template from the previously printed trailing edge curvature and trace it to the wings as shown. Next cut out along the curve line forming the trailing edge. Do this by holding the folded sheet firmly and cut as close to the curvature as possible. When opened up, you will get identical curved wings on both sides.
Trace and cut trailing edge
Step 12: Cut Center Fold Again
Now use the razor and cut the center fold as before, but this time only HALF of the length as shown by the RED line in the previous photo. This cut allows 1 final fold to the leading edge, it also stiffens the wings and gives the right aspect ratio.
Cut center fold again
Step 13: Cut Center Fold Halfway...
This photo shows the exposed view of the center fold being cut halfway.
This cut will allow the final fold for the leading edge of the CanardWings.
cut center fold halfway
Step 14: Forming the Canards
Now to fold the canards. Just fold it along the folded center fold, crease and unfold, repeat on other side and flip over:
Folding the canards
Step 15: Final Fold of the Canard
Fold the right edge to meet with the center fold.
Then fold the whole folded canard to the left again, repeat on other side.
Fold in the canard
Step 16: Almost Done...
Now spread open the center fold, this is what you should get:
Spread it open
Step 17: Staple the CanardWings Together
Next carefully align the spread wings and canards centrally, staple ONCE across the center fold.
Staple it...
Step 18: Underside View of CanardWings
This is a shot from underside, your almost finished CanardWings should look like this.
The stapled is bent slightly to create a dihedral and the staple retained the shape well. The degree of angle of dihedral plays an important role on the flight characteristics of the CanardWings. Experiment and have fun.
A view from under side
Step 19: Finishing Touch...
Slightly bend UP the trailing edge. This creates a foil that gives the wings lift.
Bend up the trailing edge
Step 20: Now Launch the CanardWings
Hold the CanardWings as shown in photo.
To launch hold it above your head and lightly toss.
This wings are great indoors and outdoors...tweak the trailing edge and canards (can be slightly bend DOWNWARDS) to create different flight patterns...enjoy your flight!Hold this way to launch
Step 21: Video of CanardWing's Long Distance Flight...
It flew to the left and was hidden was a few seconds and then came back into view, appearing on the left screen again, flew across the street towards the opposite apartment block and was blown back. It finally landed on the top deck of a multistorey carpark.
A slightly larger and better video hosted by VEOH
