Introduction: Canjo - One String Banjo
You will need:
A 500 mm long stick. 20x20 mm
A small can
A bit of strong, twinned string
Some nails
Tiny pieces of hard wood 4x4 mm
Glue
Step 1:
Draw a line in the middle of the stick parallell to the edge.
Mark the length of the can.
Step 2:
Cut along the line.
Fasten a nail in the other end. Let it stick up about 15 mm.
Step 3:
Press the stick over the edge of the can.
Fasten it with two small nails.
Step 4:
Make a small hole in the bottom of the can about 20 mm from the edge at the same side as the stick.
Glue the first fret that will keep a distance between the fretboard and the string.
Step 5:
Cut the string a bit longer than the stick.
Tie a washer in the end of the string.
Drag the string and tie it as tight as possible around the nail.
Step 6:
Measure the total length of the string.
Divide the length as the image shows for a blues tuned canjo. Use other intervals if you like.
Glue frets on the fretboard.
Step 7:
Decorate the canjo if you wish.
You can use the washer to tighten the string by turning it.
String Challenge
