Introduction: Captain Twmffat's Dark Spiced Rum
Some hundreds of years ago, the only way that sea going folk, including pirates, could sustain the constant onslaught of bad weather, scurvy, rancid smelling body odour and other similar discomforts was by way of their daily ration of grog - and traditionally this was an alcoholic drink called rum. Often, a swift glug of delicious rum was all it took to persuade the crew to go out on deck in a howling gale to trim the sails or prepare the lifeboats. Interestingly, the most common cause of mutiny onboard pirate ships was not bickering about dividing out treasure, but running out of rum, which, whilst out at sea was more precious than any gold trinket.
In reality, alcohol is a very effective anaesthetic and can easily fool the brain into believing that the dangers of the sea are far less than they really are. In times gone by, especially on pirate ships, the concept of health and safety was not foremost on the captain's mind and with the absence of safety lines and harnesses and proper wet/cold weather clothing, extra rations of rum was the only way he could persuade his crew to brave the elements. Thank God we don't do this anymore!
Disclaimer: Please do not trim sails or perform other hazardous activities whilst under the influence of alcohol. The above section is for historical reference only.
Rum is thought to have originated in the Caribbean which was a popular stopping point for pirates and other ships of dubious patronage. It was first discovered when brewing with sugar cane and accidentally overcooking the sugars to produce caramel, which has a very characteristic 'chocolatey' flavour.
Step 1: Ingredients
- 1.05 kg sugar cane molasses
- 0.2 g liquorice powder
- 0.4 g dried angelica root
- 0.4 g chopped Madagascan vanilla pods
- 1 g safale 004 brewer's yeast
Obtaining the molasses can be quite confusing as quite a few different products are called 'raw sugar cane'. The trick is to look at the carbohydrate value in the nutritional profile on the label. The sugar value should read 95 g per 100 g and not more than 96 g. The molasses should be dark and compact with an amazing smell and exquisite taste! NB. Never use sugar beet molasses.
Step 2: Equipment
- Air Still
- 1 gallon demijohn (optional)
- Demijohn bung and airlock (optional)
- Separating funnel (optional)
- Scales with range 0 to 200 g, accurate to 0.1 g.
- Saucepan and wooden stirrer.
Step 3: Making Caramel From Molasses
50 g of Molasses was added to a saucepan and gently heated and stirred until it reached it's smoke point (160 degrees C). Once smoking, quickly remove from the heat and stir vigorously. The photos show the process and, just before adding the water, we have a smoking light brown creamy substance.
The brown cream was allowed to cool to just above 100 degrees C and then the pan was tilted to one side and 50 ml of water was added. Tilting prevents the water from boiling off as there is less contact with the hot sides of the pan.
The last photo shows the final product which needs to be stirred over a very low heat to dissolve all, or at least most, of the sticky brown lumps. Eventually, we should have about 100 ml of liquid black caramel goo.
Making caramel like this is fairly tricky and it's highly advisable to try the process beforehand with ordinary refined sugar.
Step 4: Botanicals
Since we are only making 750 ml of rum, we only need a tiny amount of botanicals as we don't want to completely overpower the flavour of the molasses.
- 0.2g of powdered liquorice
- 0.4g of dried angelica root
- 0.4g of chopped Madagascan vanilla
Total botanicals = 1.0 g
These ingredients are added to the rum at the bottling stage and allowed to infuse for at least one month.
Step 5: Making the Molasses Wine
Add 1.0 kg of the molasses to 2 litres of water in a saucepan and warm to about 60 degrees, stirring to dissolve the sugars.
Once fully dissolved, allow to cool, or it will crack the demijohn, and pour into the demijohn., topping up with water. The OG should now be about 1075. Any higher than this and it won't ferment.
Add about 1g of safale 004 brewer's yeast to the liquid, put in the bung and airlock and store in a warm place for about 10 days to ferment.
Step 6: Distillation / Rectified Spirit
Distill the molasses wine to 50% alcohol, which will be diluted to about 40% when the liquid caramel is added. Click HERE for more info on distilling technique using an air still.
The 'Making the Molasses Wine' step and the 'Distillation' step could be left out if you can get hold of some rectified spirit. Check out: Spirytus Rektyfikowany, but remember it's 95% alcohol so firstly needs to be diluted 1:1 with water to get it down to approx. 50%. 'Proper' rum should, however, be distilled from molasses wine to get the full flavour profile.
Step 7: Labelling
Create a fancy label - or use mine if you like!
Have a quick taste of your concoction, just to check nothing's too obviously wrong with it. It will seem a bit 'harsh' for the first ten days or so but will rapidly improve and should be fit to have another sample after 2 weeks. It will then keep on improving in the bottle for months/years. No need for a wooden cask for this to occur, but if you want the authentic pirate experience, then by all means cask it up!
There will be some sediment in the bottom of the bottle, which can be most easily separated by using a separating funnel (see 'Equipment' step). Mine is a 500ml funnel, so I poured off the top 250 ml from the bottle into another bottle, then pour the remaining 500ml into the funnel and wait a few days before opening the bottom valve to remove the dregs.
Please drink responsibly and do not use alcohol when changing the sails on a ship!
Please in the competitions - top right - Thanks! |
Homemade Gifts Contest 2016
Brave the Elements 2016
Vegan Food Challenge
Epilog Contest 8
