Cardboard Box Water Ballon Prank(super Simple)
Introduction: Cardboard Box Water Ballon Prank(super Simple)
Super simple prank with cardboard boxes
Follow these steps and you would have it done in no time
PLEASE VOTE FOR THIS PROJECT
TIP build it a bit messy (it makes it seem less serious :D )
Step 1: Tools & Materials
Tools
-compass
-x-acto knife
-hot glue gun
Materials
-cardboard box
-ballon
-small pin
-water
Step 2: Cutting Your Button
Cut a cardboard box into 22cm*7cm
Cut halfway in the middle to make a folding line.
Step 3: Cutting a Hole
Draw a circle on the top part be sure to make it 1.7cm in diameter (make it a bit smaller than your ballon's diameter)
Cut it out with your knife (SAFTY FIRST WEAR GOGGLES!)
Step 4: Stick in Your Ballon and Pin
Fill your ballon full with water(I demonstrated with confetti)
Tie your ballon and put it in the hole you cut out
Stick in your pin 0.5cm higher than the ballon(Make sure it doesn't touch the ballon)
Step 5: Hot Glue
Hot glue the ballon on the card board
Fold the cardboard into half and hot glue it together creating a button
Step 6: The Trigger Message
Write a trigger message like "Don't ever press"
Use the opposite effect to pull the prank!
Step 7: Make the Box
Cut out a hole slightly bigger than your button(To make water flow out)
Write your message inside the box
Step 8: Assemble Button and the Box
Assemble the button and the box(Again make sure the ballon doesn't pop)
Leave a small gap under the button(The water would spill out of there when it pops)
Step 9: FINISH
Put on someones desk or the front porch
HAVE FUN
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
