Hello, This is my second post and I am from Indonesia.
I made this because I want to enter in Instructable Contest. But, I need some fresh idea, differents from other people and something out of the box. Then I try to make a Drinking Glass From Cardboard.
Let's Make it !
Teacher Notes
Step 1: What You Need :
- Hot Glue Gun
- Cutter
- Scissors
- Pencil
- Ruler
- Bottle
- Cardboard
Step 2: Cut the Bottle
Cut a plastic bottle to the size of a drinking glass using a cutter. And trim the plastic bottle with scissors
Step 3: Bend the Cardboard
make lines using a cutter so that the cardboard is easy to shape. (Be careful when making lines. Must not be too deep because it can cut cardboard).
Step 4: Cardboard + Plastic Bottle
Glue the hot glue to a plastic bottle, then stick the cardboard and make it surround the plastic bottle.
Step 5: Glass Base
Add hot glue to the bottom of plastic bottles and cardboard. After that, stick to another cardboard to make the glass base. Wait a while until the hot glue dries. And then cut the cardboard to follow the shape of the glass
Step 6: Glass Handle
Draw a glass handle on a cardboard and make it into four.
Step 7: Stick the Handle !
Combine the four pieces of the glass handle together and then stick it to the glass using hot glue
Step 8: Done !
You can easily insert water into the cardboard glass without spilling the water.
Sorry for my bad English because I can only do a little and use google translate.
Thanks,
Cardboard Speed Challenge
