Cardboard Magnifier Glass
About: i love making stopmotions on youtube ( LegosRCool) also love making random stuff
Ever wanted to be a detective? Well now you can with this cardboard magnifier glass.
Supplies:
  • magnifier glass sheet
  • scissors
  • compass
  • carboard
  • hot glue gun
  • hot glue
  • ruler
  • Exacto knife
  • maker
Teacher Notes
Step 1: Measure Time
Take the compass and ruler and bring the compass to equal 1 3/8 in.
Step 2: Circle Time + Measure Time
Trace a circle with the compass at 1 3/8in. On the magnifier glass sheet.
Step 3: Cut Out the Circle
take the maker and trace over the circle on the magnifier circle and cut it out.
Step 4: Cardboard Time
trace 2 circles that are 4in in length on the cardboard. inside those circles trace 2 circles that are 2 1/2in in length.
Step 5: Cut Out Both Circles
first, cut out the inside circles then cut out the bigger circles ( refer to pictures)
Step 6: HOT GLUE TIME!!!!!!!!!!!!!!!!!!!!
take one circle and lay it down, then take the magnifier circle and hot glue that to the cardboard one. After that glue the other circle on top of the other pieces.
Step 7: Cutting Time
cut out 2 10cm long rectangle pieces and one 8 cm piece. ( i forgot to take a picture of the 8cm one)
Step 8: HOT GLUE TIME PART 2 !!!!!!!!!!!!!!
glue one of the 10 cm pieces on the bottom of the circle. then hot glue the 8 cm piece to the remaining of the 10cm piece. after that glue the 10 cm piece on top of the 8 cm and the bottom of the circle.
Step 9: Final Step
it does work as you can see from the picture. pls favorite and comment if you made it .
Hot Glue Speed Challenge
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
