Cardboard Spectrometer, Rainbows in Your Pocket
7,427
84
18
Introduction: Cardboard Spectrometer, Rainbows in Your Pocket
About: I'm an Italian freelance structural engineer, graphic designer and photographer, and I'm teaching physics in Waldorf high-schools. I always investigate electronics, robotics and science in general, I'm a pas...
Maybe you had noticed that different light sources give a wide variety of sights and sensations, especially due to colors revealed by illuminated objects. It can be true that some very nice pieces of furniture bought in a well lightened showcase, or a jewel which glittered with beautiful rainbow colors, are not so spectacular whenever you took them in your living room... let's understand together why it's so.
Step 1: What Is Light Spectrum
The spectrum of a light is the whole variety of colours which are emitted from that light source. Rays emitted can also be invisible to human eye, some can be heat, others can be different types of electromagnetic radiations. But for now we only wish to see juicy tints from any light source we run into, and wonder about how much variety of colours is in a single lamp. This could also make us thinking deeply about lighting choices for our cities and our house.
The spectrum you see in this instructable's first step comes from a fluorescent neon light, and indeed you can distinguish coloured lines detached one each other. Looking into an incandescent light, you will see that things are different, and also solar light, LED for plants growing, sodium lamps, and so on.
Step 2: Spectrometers Types
Spectrometers have different working principles. You can see the spectrum with a glass prism, with a diffraction grate, but also with a vynil record or a Compact Disc. If you look a light while reflecting on a CD you will see some beautiful colours of the rainbow. This is already a cool toy, but it needs some better setup to become a semi-professional spectrometer.
Step 3: Materials
We will actually use a CD which I hope you already have in your scrap. You also need some cardboard tubes, but pvc pipes are also good. Personally I love the surface of these cardboard tubes I found somewhere, it's smooth and can be easily sanded with sandpaper.
Then keep close at hand some adhesive tape and a piece of iron wire.
My project expect you to design and 3D print covers for the tube, but if you don't own a 3D printer don't worry, you as a good maker will have no difficult to adapt some plastic caps.
Step 4: Viewfinder and Reflector
You will be surprised to see how much simple this project is.
The viewfinder is nothing more than an hole distant about one inch from the edge. Use a drill if the cardboard is quite thick, but maybe you can manage it with a different tool. Then make it rounded and smooth with a little roll of sandpaper.
The reflector is the piece of CD-rom, just cut it like a slice of cake. The width shall be just a bit more than inner diameter of the tube. Embed this CD slice inside the tube, just under the hole, with the reflecting surface looking the hole, and an angle of about 35-40°, you will now the right angle when you will see a rainbow while looking into the hole. When you are pretty sure you can glue the piece of CD in place.
Step 5: The Stop Ring
The cap will have to rotate freely but also to stay in place. To obtain that, shape a piece of iron wire on the cardboard tube so to make a big ring, then fix it at about 1cm from the edge at the opposite side of the viewfinder, with some amount of well thighten electric tape.
Step 6: The 3D Printed Caps
Those are anything special... just a pair of caps, one with a slit. You can obtain then maybe from milk bottles, just cut a 1mm wide slit in center of one. Then adjust the iron ring and number of tape turns around the ring to obtain a perfect joint. You can also glue them in place but I don't suggest it. The rear caps is simpler to draw since it doesn't need a slot even a slit.
Anyway, if you own a 3D printer it's time to make something cool. Use a 3D software to design caps like in the pictures, with right diameters to get stuck around the ring and the tape. I used Rhinoceros but any software will be fine since it's a very simple shape. Please refer to other instructables to know something more about slicers and printing parameters.
When you have both caps you can simply embed them in place. The front top also rotates so you can see different effects when light comes directly through the slit, just point the tube toward the light and look into the hole.
Colors of the Rainbow Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
    18 Discussions
    alcurb
    alcurb
    Question 1 year ago
    I have some nuts and bolts questions regarding the construction:
    1. How do you safely cut the CD without mangling or scratching it?
    2. Would you necessarily get better performance if the interior of the tube and caps were painted flat black?
    3. In your instructions, you indicated to cut the CD wedge a little wider than the diameter of the tube, but I would like to know: how wide should the wedge be on the hub end? Seems to me that it might be a somewhat critical measurement if you want to seat the wedge at a 40-deg angle inside a cylinder.
    4. What would be the best kind of disc ("CD") to produce the full rainbow effect, mass-produced Audio CD, CDROM, DVD, Bluray disc, ....?
    andrea biffi
    andrea biffi
    Answer 1 year ago
    My dear,
    it seems that you didn't get the aura of simplicity which blows gently around this project, but believe me, it's much more simple than you could think. Just make it, with toilet paper tube and the worst audio CD you still own, only your fingers to make the slot... No 3d printed parts, no prints, no technology and no concern at all, it will work great!
    beaskywalk
    beaskywalk
    Reply 1 year ago
    When you write "cut as a cake" do you mean with a knife? I have no idea how easy they cut. But with your reasurance that it's simple I should probably just try.
    andrea biffi
    andrea biffi
    Reply 1 year ago
    I mean slice a cake... you can use a cutter, so to engrave a groove, maybe on both sides, then bending the CD you can brake it along the line.
    beaskywalk
    beaskywalk
    Reply 1 year ago
    Thanks for the additional explanation!
    4
    rkrishnan7
    rkrishnan7
    1 year ago
    Great project! You deserve extra credit because it is built without Arduinos, Laser cutters, 3D printers or CNS machines. (not that I have anything against them!) Spectroscopy is so fundamental in understanding the world around us, and by making it accessible to all, you help enlighten all of us!
    greyaria
    greyaria
    Reply 1 year ago
    I agree with you 100%. So many 'DIY' projects require a 3D printer or some other such machine which can still be very inaccessible to a lot of people. It's nice to find a project that everyone can do, not just those who have enough disposable income to buy something like a 3D printer.
    5
    alcurb
    alcurb
    1 year ago
    Very nice! You can actually do some science with your project.
    Check out publiclab.org and spectralworkbench.org. They have a spectrometer of similar design to yours, but theirs is made of folded paper and is very flimsy, that is, it's very easy to damage, while yours is very robust as it can take some beating in the field.
    In spectralworkbench.org, there's a web app (and python stand-alone one as well) that can process the spectrum you photographed for analysis. Not only can you tell the composition of glowing gasses, such as neon, argon, xenon, sodium, mercury, sun, etc, but you can also identify non-gaseous materials by analyzing the reflected or transmitted light from the material. Imagine filling a glass vial with a material, say a drop or two of dish soap in water, then you shine sunlight through it recording and analyzing the spectrum you obtained from the material. You would now have a spectral profile of that dish soap in your database.
    You can amass a database of spectrum profiles for later use. So if you ever encounter an unknown substance that you analyze with your spectrometer, you might identify what it is from comparing it's spectrum with the data you already collected.
    Don't you love this sciency nerdy stuff?
    I voted for your project.
    andrea biffi
    andrea biffi
    Reply 1 year ago
    Your links are awesome! I still cannot believe there is so many people every day in the world examining light spectrum!
    andrea biffi
    andrea biffi
    Reply 1 year ago
    Yes! It's really awesome! And kids love this too, they could learn amazing topics with very easy diy stuff! :-)
    I'm actually holding physics classes in Waldorf high-schools, and these projects are an essential part of teaching!
    Aeon Junophor
    Aeon Junophor
    1 year ago
    Hi andrea!
    Take a bow!!
    It is such a wonderful project and I voted for you!!
    With many greetings from Hamburg ;-))
    Yours Aeon Junophor
    andrea biffi
    andrea biffi
    Reply 1 year ago
    Thanks Aeon! You're projects rock too!
    andrea biffi
    andrea biffi
    Reply 1 year ago
    Your projects rock too... Damn corrector ;-)
    4
    egon1990
    egon1990
    Question 1 year ago
    i dont understand where to put the cd. please make a diagram or sketch.
    andrea biffi
    andrea biffi
    Answer 1 year ago
    It's there!
    andrea biffi
    andrea biffi
    Answer 1 year ago
    You're right... I couldn't take a good picture but today I will add a sketch!
    jessyratfink
    jessyratfink
    1 year ago
    What a great idea! :)
    andrea biffi
    andrea biffi
    Reply 1 year ago
    Thanks Jessy, it's a tool set I built for my optics physics class, we observed many different lamps, it was great.
