Cat Bed+Scratching Post!
This is a pretty basic scratching post/ cat bad structure. Three things are included in it: cat bed shoebox, cardboard cat scratching post, and handmade chopstick-string cat toy.
All you will need is:
- A cardboard scratching block
- 2 long wooden blocks
- A flat piece of plywood
- 1 shoebox
- 1 chopstick
- A piece of string about 1' long
- Scissors
- Drill
- Screws
- Hot Glue Gun + Sticks
- Pillow
Teacher Notes
Step 1: Bottom Supports
Cut 2 identical wooden poles how long your desired cat scratching block is. (not including bed)
Step 2: Attach the Poles to Headboard
Fasten the supports to a flat piece of wood as long as your desired scratching block is. Then screw a base of plexiglass to the bottom supports. (Plexiglass bit optional)
Step 3: Bed Base
Screw or fasten a shoebox to the other end of the poles.
Step 4:
Put a pillow into the shoebox. This will make the bed.
Step 5: Create Scratching Bed
Hot glue the cardboard scratching post to the plexiglass or wooden lower beams.
Step 6: You're Done!
Thanks for completing this cat bed! Painting is a great way to finish it off, but of course that is optional.
Pets Challenge
Pets Challenge
Be the First to Share
    • Furniture Contest
      Furniture Contest
    • Reuse Contest
      Reuse Contest
    • Hot Glue Speed Challenge
    Nice. My cats would love one of these, Good luck in the Pets contest.
