Catgenie : How to Use Refilled 120 SaniSolution Cartridge
77
Introduction: Catgenie : How to Use Refilled 120 SaniSolution Cartridge
***** Warning this requires modification to your CatGenie 120. Your warranty will be voided. *****
Background:
The CatGenie 120 SaniSolution cartridges use and RFID tag monitor the remaining used cycles. THe RFID tag has to countdown counters that are reduced by one each time the CatGenie runs a clean cycle. When the counters reach zero the cartridge is considered empty. The counters can only be reduced in value witch prevents you from just refilling the cartridge and reusing it.
Information:
The CatGenie RFID reader uses the CR14 RFID reader chip.
The Cartridges use the SRIX4K-A4S_1GE RFID tag.
Goal:
Emulate the RFID reader and tags used by the CatGenie 120 so that refilled SaniSolution cartridges can be used.
Tools needed:
  1. Wire cutters
  2. Soldering iron
  3. Drill
  4. Needle nose pliers
  5. Philips head screw driver (long shaft)
Supplies used:
  1. Arduino Nano (or compatible)
  2. Double sided mounting tape
  3. 6 inches wire (I used 22 gauge solid core.)
  4. Solder
Teacher Notes
Step 1:
The CatGenie connects to the RFID reader via I3C bus connection.We will use the Adruino wire library to connect to the CatGenie, To the CatGenie, the Adruino appears as a RFID reader. The Adruino needs to respond as if it was the RFID reader reading a tag.
Open CatGenie housing by removing 4 screws. One of the screws is covered by the anti tamper warranty sticker.
Unplug jumper from RFID board.
Drill hole to run wire from Adruino to connector for RFID reader in case.
Step 2:
Upload CatgenieCartridgeEmulation-3.ino file to the Adruino.
Using the wire connect. (directions are for Adruino Nano. Consult pinouts if using a different board)
  • White wire to Adruino pin A5.
  • Black wire to Adruino pin A4
  • Red wire to Adruino Power(5v)
  • Blue wire to Adruino Ground
Step 3:
Using double sided mount Adruino to the CatGenie.
When reset, the Adruino resets the count to 120.
To use a refilled cartridge, insert cartridge as normal and press the reset on the Adruino.
Watch this video on how to refill the cartridge.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
    4 Discussions
    Alex in NZ
    Alex in NZ
    22 days ago
    Great hack for getting round that nasty little lock in. Thank you for sharing :-)
    OwenM54
    OwenM54
    Reply 22 days ago
    You're welcome.
    OwenM54
    OwenM54
    Reply 27 days ago
    You're welcome.
