Celeriac, Pear & Blue Cheese
432
4
Introduction: Celeriac, Pear & Blue Cheese
About: Hi, I'm Éva from Hungary. I love baking, cooking, and gardening, not to mention the perfect combination: cooking using fruits and veggies from our garden. I often experiment with new ingredients and try to use…
Celeriac is one of my favorite vegetables, it is widely used in Middle - Europe. It has a dominant role in the classic Sunday beef or chicken broth, but it can also stand on its own. It has a deep, earthy, celery-like flavor, with a nutty aftertaste. Try it as a cream soup, in slow-cook dishes, you can use it for making chips, julienne it and fry it in oil or simply add it raw to your salad. It's easy to work with and as you see, there is a number of ways you can include it in the menu. It can be paired with various vegetables, it gets on well with beetroot, nuts and cheese.
Step 1: Ingredients
Celeriac cream:
600 g celeriac (roughly, 1 big or two smaller ones)
120 g butter
500 g milk
large pinch of salt
Cheese balls:
150g cream cheese
200 g cheese of your choice
80 g blue cheese
a handful of walnuts
Caramelized pear:
2-3 pears
fresh rosemary (1 tablespoon)
2 tablespoons butter
Step 2: Preparing the Celeriac Cream
Clean the celeriac, peel it and cut it into chunks. Don't worry too much about the size, you'll blend it anyway. Put the butter into a saucepan and melt it at low heat. Add the celeriac and saute it. Add the milk and the salt, bring it to boil, then lower the heat and cook it for about 45 minutes, until the celeriac gets real soft. By then, the milk should be concentrated.
Step 3: Preparing the Pear
Finely chop the rosemary, peel the pears, remove the seeds and cut them to 0.5 cm x 0.5 cm cubes, or tetrahedrons, if you prefer. Or, as a matter of fact, the combination of the two.
Step 4:
Heat the butter in a saucepan, add the pear cubes and the chopped rosemary. Fry it until it gets a light brown color here and there.
Step 5: Walnuts
Without adding oil, fry the walnuts in a saucepan, until golden brown. Then chop them fine.
Step 6: Preparing the Cheese Balls
Grate the cheese and combine it with the cream cheese. Add half of the walnut, mix. Wet your hands and form the cheese into small balls, then cover them in chopped walnut.
Step 7:
Using an electric blender, blend the celeriac cream.
Step 8: Finishing Touches
Put the cream on the plate, top it with the cheese balls and the pear.
Side Dishes Challenge
Be the First to Share
    • Potato Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Build a Tool Contest
    3 Discussions
    fenyvesi
    fenyvesi
    1 year ago
    Meg fogom csinálni, finomnak tűnik. Nem csak a recept, de az angolsága is kiváló. Üdv: Fenyvesi György
    Momos75
    Momos75
    Reply 1 year ago
    Köszönöm!
    jmdushi
    jmdushi
    1 year ago
    Fruit&vegetables a perfect combination. I will definitely make this!
