Cheap, Good Quality Shuriken Throwing Star
121,587
432
173
Introduction: Cheap, Good Quality Shuriken Throwing Star
I've searched and searched, but no where could I find instructions on how to make a nice, high quality, amateur throwing star. In this instructable, I will guide you through the process of making a steel shuriken for under 10$ (if you already have the tools).
DISCLAIMER: This is a WEAPON and is not for just throwing around at people, pets etc. It can SERIOUSLY injure or even KILL somebody. The blades are extremely SHARP. I am not responsible for anything that you do with this. If you are foolish enough to throw it at a person or a pet then just stop reading now.
Have fun and BE SAFE!!
Step 1: Getting the Stuff
A minimum of what you need:
-A metal plate of some sort, relatively thick. It should be no larger than 5 inches or you will waste a lot of material. I used a galvanized steel electrical box cover I got from home depot for about $0.60. This works VERY well.
-An angle tool, or something that can measure and draw straight lines exactly perpendicular to the sides of the plate
-A pencil
-A jigsaw OR:
-A hacksaw with steel cutting blades (much slower and harder)
-If a jigsaw, high speed steel cutting blades. A pack of 3 cost me about 5 bucks.
-A bench grinder or equivalent (steel belt grinder, dremel, etc)
-3/8" steel drill bit. Mine was a zirconium coated bit from a big set my dad got. You could also buy a cobalt bit, but a 3/8" one would run you about $10. Ouch
-A drill that can run at least 800 RPM, hopefully with a lot of torque
-Metal file
-240 grit metal sanding sand paper (needed to make the pencil marks show up on the plate)
OPTIONAL:
-A drill press (I didn't have one so I was just careful. It isn't vital for the holes to be that precise)
-Some silicon carbide metal sandpaper (60, 120, 240, and if you want it really smooth, 400 and/or even 600 grit paper. Whatever you want to do.
Step 2: Prepping the Plate
In order to draw on the plate with pencil, it needs a rougher texture than the glass smooth-ness that it comes with. You only need to prep one side.
Start with 60 grit silicon carbide sandpaper if the metal has lots of bumps. If not just use 240 and sand in small circles until the whole thing is done. You should be able to make a mark with your pencil.
Step 3: Drawing the Base Square
Find two touching sides that are perfectly flat. If all of them are flat, then just pick a top and a side and scribble close to the very edge. Only put the flat of the right angle tool on these sides and only measure from these two sides. Now measure and draw a 2 1/2 inch square in the very center of the plate. For example, on my 4 inch plate, I had to measure in 3/4 of an inch in from the edge and drew a line. Then I measured 2 1/2 inches farther and drew a line there. So now I have 2 parallel lines that are 2 1/2 inches apart. Repeat this in the other direction and you will have a perfect square. Now, find the midpoint of each side of the square and mark them. Now draw a straight line between them. You should now have 4 small squares. The picture can better show what I mean.
Step 4: Drawing the Star
From each midpoint, measure 3/8" straight in and mark there. These are the inside points of the star. From there, draw a line from the two nearest points of the square to the newly marked spot. Repeat this 4 times on each side. You should now have a basic star shape. See the picture if you don't quite get it.
Step 5: Drilling the Holes (optional But Looks Way Cooler)
Now if you have a drill press, this step will be a breeze. If not, then, like me, you just have to be careful. You are going to be drilling at inside star points. It's kind of hard to explain, so look at the image for reference. You are going to use the 3/8" drill bit for these holes. If you don't have a drill press, it would probably be easier if you use a bit about half the size to drill a hole first. It's hard to get a big bit to go exactly where you want in one shot. You can be more precise with smaller bits. Also, if you want to counter any wind blowing it off target, drill a hole in the center.
Step 6: Cutting It Out
Now it's time to cut the thing out. If you have a jigsaw and you drilled the holes, start from the inside of the holes and go out. If you didn't drill the holes, then you just have to start from the outside. If you don't have a jigsaw, then don't bother trying to start from the inside of the holes. You need to clamp the plate down, I shouldn't need to explain the reason for that.
(The ideal tool for this step would be a bandsaw, but most people don't have one of those, and they're pretty expensive. However, you could go down to your local machine shop and see if they'll cut it out for you)
Step 7: Cleaning It Up
Now you need to clean up the edges of the star, since they will probably be pretty rough. So, using the grinder, flatten the edges up, or use a file, which will take a lot longer.
Step 8: Sharpening
This step is semi-optional, but I would recommend it. Now that your sides are flat, use the grinder (or a file) and grind edges onto the star. They should be at about a 45 degree angle. When you finish grinding an edge with the grinder, quench it in some water and slosh it around to cool it off (its SUPER hot).
Step 9: Finish!
Now your star is complete! If you want, you can make the edges razor sharp with a fine file, or whatever, but remember this isn't super high quality steel, so it probably won't hold an edge for long.
Now remember, Have Fun but BE SAFE!!!
1 Person Made This Project!
  • Pocket-Sized Speed Challenge
  • Metalworking Contest
  • Maps Challenge
    Maps Challenge
173 Discussions
ice hawk
ice hawk
12 years ago on Introduction
aaghr how hard will it be to make one of theses with a hacksaw and file ..... i can find any metal at my harware store ... and these shuriken stars are sooo awsome
ryan7071
ryan7071
Reply 3 years ago
I made one without cutting or filing
KennyN1
KennyN1
5 years ago on Introduction
Weapons are designed primarily to cause death. Certain poisons might enhance a weapon's ability to stun or keep the target down. I agree that poisons aren't something to play around with, but I also believe that poisons make for effective weapons.
spenfisher12
spenfisher12
10 years ago on Step 9
if you heat it up to red hot and throw it in water it gets harder but more brittle its a give take thing it can hold an edge or not chip or break
ninja of suburbia
ninja of suburbia
Reply 10 years ago on Step 9
 actually, you want an orange heat on the steel, and yeah throw it in oil, heads for flare-ups.  also, when you're done with that, polish it with sandpaper, and then take a blowtorch to it.  the polished surface will change colors, so pay attention.  when it hits a gold to dark yellow color, let it cool and you're good to go.  don't hold the torch in one spot, though, keep it moving so you get an even temper.
MerlinMakes
MerlinMakes
Reply 5 years ago on Step 9
depends on the steel alloy. tempering is more in-depth than that, and varries from one metal to another. there ARE charts on the internet though, if you happen to know what kind of steel you actualy have....
for the source of the plates, i'd say that'd be hard to track down. i would also worry about galvanized steel. if it's zinc plated, at the very least people do this where it is /very/ well ventilated. safety!
knex luver234
knex luver234
Reply 8 years ago on Step 9
this is a good technique, origionally used for knifes, but it is very hard, not easily done for a person mot knowledge in the subject, it takes practice
harley_rly
harley_rly
i've heard of doin somethin similar, its just instead of water, you use oil, and it increases the carbon content of the steel, of coarse with thowing weapons you typically dont want something very brittle, due to the amount of shock force caused from impact
triumphman
triumphman
8 years ago on Introduction
made some of these once, got a nice scar to prove it! It spun free when I was drilling the hole. Not pretty site. Red stuff on stainless steel. My own. Now I wear gloves, thick gloves, leather re-enforced gloves for welding! We learn by our mistakes and sometimes stupidity, too late! I eventually gave them away. Everytime I reached for them I got a cut! Not practical or worth the effort to make. So don't bother. Ninjas can keep them. I'll keep my 44 magnum!
MerlinMakes
MerlinMakes
Reply 5 years ago on Introduction
i'd like to suggest to anyone who's going to try and make these that you drill the hole first.... then cut out the sharp bits. though i abhor gloves /anywhere/ near a drill or saw... for the same reason you dont wear a ring or other jewlry around power tools.
asside from the points, the sharp edges should be the /last/ thing to be put on, and that goes for anything sharp. the points are inevitable due to the shape, but dont you dare sharpen them till they're finished. and even then be careful. square edges still cut, especialy if they get caught by a drill.
TheCommander
TheCommander
5 years ago
very cool I will use this.
Dakota Joel98
I actually make these on a semi-regular basis, but I hardened mine with Oil, so you can throw them at concrete, and it barely dulls the blade, so with a wood target they work beautifully!
bcavaciuti
bcavaciuti
7 years ago on Step 6
could use an angle grinder with a cutting disk in it. if you concentrate its easy to be accurate :D
silvertinkerer
silvertinkerer
7 years ago on Step 8
Try using a dremal for de burring. Mine was great for that. I polished mine up to a shine as sugested by pearldrummer. I was able to use it to reflect the sun light into a friends eyes befor throwing it, getting a better score because I could see the target. He could not see it as well for a few mins.
doughnutguy1
doughnutguy1
Good thing I live in Missouri. No one cares here! I can ship ANYTHING from Trueswords to my house, and it tells you states it cant ship t
o.
Takeda8
Takeda8
Too bad these are illegal in Holland and many country's aswell.. but in my opinion if you practice safe and without bothering anyone.. the who cares ;)
Takeda8
Takeda8
This has to be the best shuriken tutorial i've seen so far ;)
fkhalsa
fkhalsa
9 years ago on Step 5
Using a metal punch will help your bit stay centered.
This looks kinda like a metal handle with a sharp pin coming out of it, and it's sprung load so that it will 'click' when you press it all the way down, creating a small dent in the metal.
Should be easy to find at any hardware store.
