Cheap Grinder Bit for Robotic Events
Step 1: Materials Required
All r Robotic scraps
One spare plastic wheel
One sandpaper sufficient enough to cover the entire perimeter of the wheel
One axle or rod slightly larger than the hole of the wheel (it's for a reason but the difference should not be greater than 1mm)
Araldite or some local epoxy
Step 2: Procedure
first take the rod and hammer it to the centre of the wheel such that it makes a tight fit
Apply some epoxy for safety
Be patient enough to let it dry
Then stick the sandpaper across the perimeter of the wheel with epoxy thoroughly otherwise at high speed it may break away
Be patient enough for it to get dry cause it is the most important step otherwise it may lead to accidents
After all of this u will be having a fully functional drill grinder bit
Step 3: Usage
first tight ur self made bit to the drill tightly
And you r good to go
It reduces the end moment effort and also helps u attain perfect tape peeling wedge
All Robotics fan and botmakers if u guys realise how beneficial this is on the event days when u can do different things with the same drill.sothat u can focus more on the event rather than the heavy tools u might have to carry
We r trying to make all tools possible with the help of drill machine.
    • Fandom Contest
      Fandom Contest
    • 1 Hour Challenge
      1 Hour Challenge
    • Backyard Contest
      Backyard Contest
    tomatoskins
    2 years ago
    Hi and welcome!
    We're glad you want to share something with the community, and this project looks very interesting. However, in order to be published this project must only contain original images created by you. Please replace any stock or otherwise borrowed images with your own.
    Once you do that, leave me a message and we will publish your work!
    Thanks,
    Your friendly neighborhood instructables staff.
