Introduction: Cheap Smart Garage Door Opener
Credit
I pretty much copied Savjee's implementation but instead of using a Shelly I used a Sonoff Basic. Check out his web site and YouTube Channel!
https://www.savjee.be/2020/06/make-garage-door-ope...
https://www.youtube.com/c/Savjee/
Assumptions
- You have a Home Assistant instance running and you know how to use it
- You have a ESPHome instance running and you know how to use it
Sonoff Basic - https://www.amazon.com/Sonoff-Remote-Control-Comp...
Contact Sensor - https://www.amazon.com/gp/product/B07F314V3Z/ref=...
USB To Serial - https://www.amazon.com/gp/product/B00IJXZQ7C/ref=...
Heat Gun - https://www.amazon.com/gp/product/B00IJXZQ7C/ref=...
Soldering Iron - https://www.amazon.com/gp/product/B00IJXZQ7C/ref=...
Heat Shrink Tubing - https://www.amazon.com/gp/product/B00IJXZQ7C/ref=...
Wire - https://www.amazon.com/gp/product/B00IJXZQ7C/ref=...
Wire Sleeve - https://www.amazon.com/gp/product/B00IJXZQ7C/ref=...
Dupont Cables - https://www.amazon.com/gp/product/B00IJXZQ7C/ref=...
Software:
Home Assistant - https://www.home-assistant.io/
ESPhome - https://www.home-assistant.io/
ESP Easy - https://www.home-assistant.io/
Step 1: Modifying the Sonoff RF R2 Power
DISCLAIMER
I am not an electrical engineer and do not pretend to play one on the internet. If you decide to modify a Sonoff Basic you are doing it at your own risk. This is how I have modified my Sonoff Basic but do not recommend that you do the same. I am also not implying that I am doing it correctly or safely.
Getting started
Csongor Varga makes a good point in his video about it not being safe to modify this version of the Sonoff like the previous version by cutting the trace. See more here. The solder connection for the relay and the solder connection for the fuse that supplies power to the circuitry are too close to do the cutting trace method. I got around this by removing most of the trace and relocating the fuse.
- Locate the fuse that supplies power to the circuitry
- Location where the neutral wire in soldered onto the inlet
- Desolder the fuse, remove, and set aside
- Desolder the neutral wire from the inlet and remove
- Cut out the trace as seen in the photo on step five
- Cut out a notch as seen in the photo on step 6
- Solder the fuse the opposite way you took it out and solder the long end to the line inlet
- Strip the neutral wire and solder it to the board as seen in photo on step 8
Step 2: ESPHome - Creating the Software
switch:
- platform: gpio
pin: 12
internal: true
We will need a binary sensor for the contact sensor that will tell us if the garage door is closed or open. binary_sensor:
- platform: gpio
pin:
number: 3
mode: INPUT_PULLUP
name: "Garage Door Contact Sensor"
internal: true
filters:
delayed_on_off: 500ms
We can configure the button on the Sonoff to toggle the relay. - platform: gpio
pin:
number: 0
inverted: True
mode: INPUT_PULLUP
on_click:
then:
- switch.turn_on: relay_1
- delay: 500ms
- switch.turn_off: relay_1
Finally, a cover with the attribute garage. cover:
- platform: template
device_class: garage
lambda: |-
if (id(contact_sensor).state) {
return COVER_OPEN;
} else {
return COVER_CLOSED;
open_action:
- delay: 0.5s
close_action:
- delay: 0.5s
Here is the full YAML. wifi:
ssid:
password:
manual_ip:
static_ip:
gateway:
subnet:
dns1:
dns2:
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid:
password:
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
substitutions:
# Modify variables based on your settings
hostname: 'sonoff_basic_4'
esphome:
platform: ESP8266
board: esp01_1m
board_flash_mode: dout
status_led:
pin:
number: 13
inverted: True
binary_sensor:
- platform: gpio
pin:
number: 3
mode: INPUT_PULLUP
internal: true
filters:
- platform: gpio
pin:
number: 0
inverted: True
mode: INPUT_PULLUP
on_click:
then:
- delay: 500ms
switch:
- platform: gpio
pin: 12
internal: true
cover:
lambda: |-
return COVER_OPEN;
} else {
open_action:
- delay: 0.5s
close_action:
- delay: 0.5s
sensor:
- platform: wifi_signal
update_interval: 60s
- platform: uptime
text_sensor:
- platform: version
Step 3: ESPEasy - Flashing the Sonoff Basic
You will need a USB to serial adapter for this.
- The RX on the serial adapter goes to the TX on the Sonoff
- The TX on the serial adapter goes to the RX on the Sonoff
- In ESPHome compile the code
- Download the binary
- Copy the .bin file to your ESPEasy directory
- Attach your serial wires to the Sonoff
- Hold down the button on the Sonoff and plug in the Serial to USB adapter to your computer
- In the ESPEasy directory Open FlashESP8266.exe
- Select your COM port
- Select the .bin
- Click Flash
Step 4: Wiring Everything Up
- Solder a wire to the RX terminal on the Sonoff
- Solder a wire to the GND terminal on the Sonoff
- Attach wires to the outgoing neutral and line terminals
- Put the Sonoff case on
- Cut the inlet side of an extension cord, strip the wires, and attach it the the Sonoff's line and neutral inlet
- Screw the Sonoff's caps on ensuring that the inlet wire is secure
- Test to make sure your contact sensor and relay are working correctly
Step 5: Attach to the Garage Door
- Attach the contact sensor (I attached mine to the pulley)
I didn't have any wire electronics wire so I used some speaker wire and cable wrap to attach the contact sensor.
- Attach the Sonoff to something (I used the bracket holding up the garage door opener)
- Connect the cables
Step 6: Home Assistant Automation - Notification If Garage Is Open for 2 Hours
Trigger: If the garage door is open for 2 hours
Action: Send notifications to my phone, my girlfriends phone, and to my home discord channel
automations.yaml
- id: notification_if_garage_is_open_for_2_hours
alias: "notification if garage is open for 2 hours"
trigger:
platform: state
entity_id: cover.garage_door
to: open
for:
hours: 2
action:
- service: notify.mobile_app_courtney_s_iphone
data:
title: "[📣][🚙]Garage left open!"
message: "The garage door has been open for 2 hours. Close it?"
data:
push:
category: ios_close_garage
- service: notify.mobile_app_pixel_3a
data:
data:
actions:
- action: android_close_garage
title: Close Garage
- service: notify.discord
data:
message: "[📣][🚙]The garage door has been open for 2 hours. Close it?"
target: ["YOUR DISCORD CHANNEL ID"]
To get a notification on IOS that has a button to close the garage door you need to add the following to the configuration.yaml file.
configuration.yaml
ios:
push:
categories:
- name: Close Garage
identifier: 'ios_close_garage'
actions:
- identifier: 'IOS_CLOSE_GARAGE'
title: 'Close Garage'
activationMode: 'background'
authenticationRequired: true # Require FaceID / TouchID
destructive: false
behavior: 'default'
Now you can add the automation that is called when you pressed the close garage door button on the IOS push notification.
automations.yaml
- id: 'ios_mobile_app_notification_close_garage_door'
alias: ios mobile app notification close garage door
trigger:
platform: event
event_type: ios.notification_action_fired
event_data:
actionName: IOS_CLOSE_GARAGE
action:
- delay: 00:00:15
- service: cover.close_cover
data:
The automation that is called when you pressed the close garage door button on the Android push notification.
automations.yaml
- id: 'android_mobile_app_notification_close_garage_door'
alias: android mobile app notification close garage door
trigger:
- event_data:
event_type: mobile_app_notification_action
platform: event
action:
- delay: 00:00:15
data:
