Introduction: Cheapest Way to Clean Wheels Like a PRO (Under 1,5$)
We use oven cleaner that cost 1,12€ to clean the rims with perfect shiny results, like a professional. It takes less than 10 minutes and it is very easy. Citroën Berlingo 2017 alloy wheels are cleaned.
You just need: Oven cleaner A buck of water Old t-shirt I bought the oven cleaner in Mercadona (Spanish version of Walmart, Tesco, Aldi).
Step 1: Clean the Wheel With Water and Old T-shirt
Clean the wheel with water and old t-shirt
Step 2: Let It Dry for 5 Minutes
Let the wheel dry for al least 5 minutes.
Step 3: Pour the Oven Cleaner Foam All Over the Wheel
Pour the oven cleaner foam all over the wheel. Until you completely cover all the rims.
Safety is number one priority: From this point wear glasses and globes.
Step 4: Wait 10 Minutes
Let work the oven cleaner between 10 or 15 minutes. No more, would be bad for your wheels.
Step 5: Remove the Foam
Remove the foam with water and the same old t-shirt. After you remove all the foam you can use a hose to remove well the oven cleaner.
