Children's Easy Skateboard
Skateboarding is an extreme sport with a high risk factor, but now many children are becoming interested in skateboarding. In order to reduce the risks brought by skateboarding, I designed this very simple skateboard. It can be said that this is a toy. It is not as complicated as the usual skateboard, and it cannot do some dangerous movements. All it could do was slide on the ground. This will reduce a lot of risks and make parents more comfortable.
Teacher Notes
Step 1: Step 1: Build the Board
1. A piece of wood 90cm long, 20cm wide and
1cm thick
2. Two pieces of wood 90cm long, 10cm wide and 1cm thick
3. Two boards 45cm long, 20cm wide and 1cm thick
4. 4 pieces of 45cm long, 10cm wide and 1cm thick combined graphic boards
5. 8 small semi-cylindrical nails
6. Assemble and assemble
Step 2: Step 2: Make the Base
Carbon fiber is used to make small wooden
stakes, and then two scaffolds are put together
Step 3: Step 3: Make Wheels
The width of the wheel is wider than the
width of the skateboard at ordinary times, which will make the sliding process more stable and improve the safety factor
Step 4: Step 4: Assemble and Decorate the Skateboard
The skateboard is finished and can be doodled at will
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
