Children's Playmat Bag
169
Have you ever been frustrated by your children's toys be scattered all over the floor? Have you ever stepped on a toy that made you mutter several words that would earn you a time-out? The Children's Playmat Bag is a quick solution to get those toys up off the floor - and it is so easy your kids can do it themselves!
Supplies:
Scissors
Wooden skewer or metal clothes hanger
Sewing machine or needle and thread
String or para cord (length will depend on your project, this tutorial is using a 20 ft para cord)
Old blanket or fitted sheet
Teacher Notes
Step 1: Sew Hem
Sew a hem all the way around your old blanket or sheet. The hem should be wide enough to accommodate your chosen string.
Step 2: String It Up!
Using your wooden skewer or metal hanger push your string through the hem you just sewed around the blanket.
Step 3: Cut Spare Length
Once you have pulled your string through the hem cut off any extra length (leave about 6 inches) and tie a knot at each end to prevent the string from being pulled out of the blanket.
Step 4: Use It!
Lay your blanket flat on the ground where your child will be playing.
Step 5: Playmat to Bag Transformation
When your child is done play simply leave the toys on top of the blanket and pull the strings tight which will form a bag. Voila! Quick, easy cleanup and portability!
Reuse Contest
This is an entry in the
Reuse Contest
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    jessyratfink
    4 weeks ago
    Nicely done and so simple :)
