Christmas Ball With SlefCAD
23
Christmas ball simple modeling and creating animations.
Teacher Notes
Step 1: Image to 3D
Select Image To 3D and use Select Image
Step 2: Select Image
Download a picture or from the Internet.To achieve the best result, the picture should be black and white
Step 3: Set Value
Set the value as on the slide.
Step 4: Scale
Use Scale , set the value as on the slide
Step 5: Sphere
Use 3D Shepe and select Sphere
Set the value like on the second slide
Step 6: Set the Position
Use Move Scale Rotate and Insert the first object(snowflake) a little into the ball
Step 7: Stitch & Scoop
Select 2 objects and use Stitch & Scoop. Set the settings as in salide
Step 8: Result
It should be a little indentation
Make a lot of such holes
Step 9: Free Hand
Use Free Hand for create numbers
Step 10: Number
Use Text andwrite 2020 in the field
Step 11: Position
Use a Scale to stretch the numbers and move in order to deepen into the ball
Step 12: Stitch & Scoop
Use Stitch & Scoop set the settings as on the slide
Step 13: Create Torus
Set the settings as on a slide
Step 14: Torus Position
Place the torus over the ball as on a slide
Step 15: Print Settings
Set the value
Quality- Hight
Infil - 20%
Suport - Enabled
Adhesion - Brim
Step 16: Result
After printing, we need to clear the model of support
Step 17: ​Decoration Ready
Choose a color and paint the ball
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
