Christmas Tree - 555 TIMER
Introduction: Christmas Tree - 555 TIMER
About: Arduino projects in my youtube channel: https://goo.gl/kDaptw Contact me:arduino.hocam@gmail.com
Hey all!
In this tutorial I will try to explain how to make christmas tree pcb.
In the industry, very useful component, known as 555 timer will be used in this tutorial. We will use 555 timer in Astable mode to create square wave with varying frequency.
Here also i have video about this project. You can have a look at this video and see how it worked.
Note that : Video language is not in English , that is why i will try to explain important parts here as in English.
Teacher Notes
Step 1: Required Hardware
In order to be able to design such an amplifier circuit, i have used the following components:
x9 3mm LED (I have used Red and Yellow color)
x9 1/4w 150 or 220 ohm resistors
x1 1/4w 1k ohm resistor.
x2 100nF capacitor (rectangel shape is used in this tutorial)
x1 10uF capacitor polarized
x1 100k trimpot (potentiometer/ see the video for shape)
x2 CR2032 battery
x2 CR2032 battery case
Soldering will also be required after we have designed the board.
Step 2: Circuit Schematic and Working Principle
In order to understand of working principle, let us have a look at the inside of the 555 timer chip.
Inside of that chip, there are 3 5k Ohm resistor( that explain where the name comes from :)) and those resistors are used for voltage division. There are 2 comparator inside the chip and output of the comparators are connected to SR Flip-Flop. When the comparison result changes, the state of the SR latch will be changed and then it will result in the ON or OFF at the output of the SR latch. Which means, it will deviate between ON and OFF states and because of this, we will be able to get SQUARE WAVE at the output with different frequency if we change the states of the SR latch in different timing periods.
However, In order to change that timing interval, we should connect capacitor and resistors to our chip. In that way, we will be able to change charging and discharging time of the capacitor by changing the resistors.
Circuit diagram is shown in the image.
Step 3: PCB ORDER
After testing,simulating and drawing the pcb file, we can give an order. After that you get the gerber file you can upload it into PCBWAY and give an order.
Here my gerber file project link: Click for Gerber File
Step 4: Soldering the Components
After we get the PCBs, we can start soldering the related components on PCB and test it. Hint: one by one put the components on the pcb , flip it and solder it by one by .
Soldering part is shown in the video as well. You can just have a look at it.
Step 5: Subscribe My Channel If You Like
Hope it will be useful project in order to understand the principle behind the 555 timer in Astable mode.
You can have a look at the video to see how this project works . If you like my project, you can have a look at others on my channel and you can support me . Don't worry about the language , mostly i prepare my codes with english explanation. If any question, you can either ask your questions from here or Youtube channel. Do not hesitate for asking any question.
My Youtube Channel : YouTube Channel (ARDUINO HOCAM)
Please Let me know if you face any problem without any doubt! Have fun!
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
