Cinnamon Rolls: No Knead, No Machine
7,071
105
33
About: Hey y'all! My name is Lydia and I want to share my passion for cooking/baking with everyone!
Hey guys, today I'm showing you how to make super easy Cinnamon Rolls without needing to knead or even using a machine! All you need is a bit of time and you'll have the most perfect soft fluffy sweet cinnamon roll ever! I hope you get it a try and you wont regret this one! So follow the step by step instructable below to make your own!
Teacher Notes
Step 1: Ingredients and Tools
INGREDIENTS
The Dough:
  • 3 ½ C All-Purpose Flour
  • 2 t Salt
  • 3 t Yeast
  • 1 C Milk
  • 1/3 C Water
  • ¼ C melted unsalted Butter
  • ¼ C Honey
  • 2 room temp Eggs
The Filling:
  • ½ C unsalted Butter
  • 1 ¼ C packed Light Brown Sugar
  • 2 ½ T ground Cinnamon
  • Cream Cheese
The Glaze:
  • 4 oz room temp Cream Cheese
  • 1 C Powdered Sugar
  • ¼ C room temp unsalted Butter
  • ½ t Vanilla Extract
TOOLS
Step 2: The Dough: Dry Ingredients
Starting with the dough, combine all of the dry ingredients in a very large bowl (keep your salt and yeast on separate sides of the bowl until you start combining everything together).
Step 3: The Dough: Wet Ingredients
In a saucepan add in the milk, water, melted butter and honey. Then go to the stove top and warm everything up on medium low until it is blood temperature (same temperature as your finger). Whisk in the eggs quickly and pour them into the mix.
Step 4: Combine Wet and Dry Ingredients
Stir the wet into the dry to make a sticky dough. You can simply mix with a spoon until there are no flour lumps left. Be sure to get in all the way to the bottom and mix completely. Scrape down the dough from the sides of the bowl.
Step 5: Cover & Refrigerate
Cover the bowl, and let the dough rise for 2 hours at room temperature. It will triple in size within that time. The two images show a before and after the 2 hour waiting period. You can see that the dough has risen perfectly. After this, REFRIGERATE THE DOUGH FOR AT LEAST 8 HOURS (over-night is best). It can be refrigerated for up to 3 days before using in case you can't get to it the next day. The gluten will continue to develop in the refrigerator. When you take it out of the refrigerator you will see that the gluten has developed perfectly by doing a simple pull and stretch test, this is quite satisfying to play with.
Step 6: The Filling
We cant have cinnamon rolls without the filling, so let's get to it! Combine the butter, brown sugar and cinnamon in a bowl. Stir until smooth. Once everything is combined, set aside. You can also tell by the color of the filling it will look dark and wet.
Step 7: Rolling It Out!
Transfer the dough to a floured work surface, and roll it into a rectangle approximately 1/4” thick. It doesn't have to be a perfect rectangle but make sure that your dough is approximately 1/4" thick, I used a ruler to measure my dough thickness. This will insure that the dough won't break or tear when you roll the buns.
Step 8: Spread the Filling
Spread the filling over the dough, I started with a fork but moved on to a spoon because it was easier. Leave a narrow margin around the edges uncovered. This way the filling won't spill out when you roll the buns in the next step.
Step 9: Roll It!
Starting with a long edge, gently roll the dough into a log shape. Don't roll it too tightly; if you do, the centers of the buns will pop up as they bake.
Step 10: Slice and Prep. for Oven
Slice the roll in half, and slice that in half and keep slicing until you have 16 “evenish” rollsIn a deep baking pan lined with parchment space the buns in the pan. Cover the pan, and allow the rolls to rise until they're have grown into each other and are puffed up, about 1 hour. Once the rolls have risen they are ready for the oven!
Step 11: Bake
Preheat the oven to 375 degrees F. Uncover the pan, and bake the buns for 40 to 45 minutes, until they're a deep golden brown. Rotate the tray during baking for even heat distribution and they will get golden brown all over. While they are baking make your glaze (next step).
Step 12: The Glaze
In a large bowl beat the cream cheese, sugar, butter and vanilla together with a whisk until well combined. I began with a whisk but ended up using the hand mixer to complete the job. The glaze should be a smooth, silky, creamy consistency.
Step 13: Remove Rolls From Oven
Remove the pan from the oven and let it rest for 20 minutes.
Step 14: Glaze the Rolls
Spread your cream cheese glaze over the cinnamon rolls.
Step 15: Enjoy!
Step 16: Video Tutorial
This is a long process but not difficult...so if you prefer an in depth video tutorial you can watch it here.
    • Spicy Challenge
      Spicy Challenge
    • Games Contest
      Games Contest
    • DIY Summer Camp Contest
    33 Discussions
    TrudyK9
    Question 22 days ago
    Hi Lyds, still waiting for your reply on the type of yeast to use...Thank you
    1 answer
    FOOD by LydsTrudyK9
    Reply 18 days ago
    Hello, sorry for the late response...I have been away on a work trip. I used instant yeast for this fliechmann's brand. Hope that helps!
    TrudyK9
    26 days ago
    Hi there, is this instant yeast you are using...If not, what kind is it? Thank you
    Build-Bot
    9 months ago
    These look absolutely amazing! Cinnamon Rolls are a treat that I wish I had more often (usually only once or twice a year) and this looks like the perfect recipe to change that! Really nice job documenting your instructable, and thank you so much for posting this!
    FOOD by LydsBuild-Bot
    Reply 9 months ago
    Your very welcome! Hope you enjoy this one Let me know how it goes if you end up trying it!
    Build-BotFOOD by Lyds
    Reply 7 months ago
    I made them, and they were delicious! The shape was pretty different from yours, I had about 15 in one large pan (12 by 18 inch) but the taste was spot-on! Thank you again for posting this!
    EDIT: I meant the shape was different from the ones I usually have; they are usually a lot smaller.
    ceelyonceelyon
    Answer 9 months ago
    November 11, 2018 Well i made both today, buns and bread. so good and yes this receipe can be made into bread.
    hiwakooceelyon
    Answer 9 months ago
    Look for no-knead-bread, there should be many ricepes on the internet. Works good and can be prepared in the evening. Wake your loved ones with the delicious smell of fresh baked bread in the mornig :D
    https://www.youtube.com/watch?v=13Ah9ES2yTU
    FOOD by Lydsceelyon
    Reply 9 months ago
    Honestly I don't know I've never tried, maybe I should... That's a good question let me know if you try that out I am super curious. It might work...
    gralan
    9 months ago
    You grabbed my attention and imagination with this tutorial, and I must now go shake the dust off of my large bowls in order to mix up a batch of these. I plan on being back to comment on my adventure. Part of what I must do is convert this to using our convection oven, as the regular oven in our kitchen is not functioning. I've had luck reducing the time by 10% and lowering the temperature 25°F. We shall see. We shall prosper. We shall enjoy! hahaha
    FOOD by Lydsgralan
    Reply 9 months ago
    Hi, I'm glad you liked it! It might to be easy but I think you will overcome and prosper! haha. You will like these for sure Enjoy! Can't wait to hear back on your amazing adventure good luck!
    gusmom
    9 months ago
    Under your ingredients for filling, it states "2 ½ T ground Cinnamon Cream Cheese". I was thinking, what an interesting idea to use cream cheese in the filling, but after reading through the recipe, realized that I believe this was not intentional! I'm still thinking that cream cheese might be good mixed with the brown sugar & cinnamon and I just might give it a try! Also, you can use dental floss or strong sewing thread (like button or quilting thread) for cutting your rolls without flattening them. You just take about 20" of thread or floss, lift the roll of dough, positioning the floss at the thickness you want your roll, then cross the ends of the floss over the top and pull opposite directions. Repeat for each slice. The floss slices right through without squishing your rolls! I learned this many years ago in Home Economics in high school and still use it to this day! Can't wait to try your recipe! Thank you for your instructable!
    FOOD by Lydsgusmom
    Reply 9 months ago
    Hi Gusmom. Thanks for your comment :-) I went ahead and corrected the ground cinnamon cream cheese on the instructions. I've always heard about the floss method but I was a bit concerned about the flavor transferring to the rolls haha... I really like the seeing thread method though I will have to give that a try next time. That is a great lesson to take from high school Home Economics lol! Thanks and hope you enjoy the recipe let me know if you try it.
    MattG197
    9 months ago on Step 14
    This is one of the best described and photographed instructables I have read. Thanks for taking the time to do it right. I am looking forward to trying the recipe, they look delicious. For the folks confused by the measurements described within (T/t), watch the video, she tells you what units of measure are needed.
    FOOD by LydsMattG197
    Reply 9 months ago
    Hi Matt, your welcome :-) You will love this recipe! Let me know how it turns out for you.
    aliasfox
    9 months ago
    Great article and very detailed, thanks. There's nothing better than home made Cinnamon rolls, store bought or even baking from frozen rolls pale in comparison. Best!
