Circular Saw Guide Under 5 Dollars
5,032
21
Introduction: Circular Saw Guide Under 5 Dollars
This is just a short insructable on how to make straighter lines with a circular saw for less than five dollars. Making straight lines is great when your making anything worth anything. And as you know by hand is usually not straight.
Step 1: Assembly
the material that I used was a one by one, 36 inch length piece of angled aluminum. This ran me about 4.50 in home-depot. I used the circular saw to cut it into 12 and 24 inch sections then using a square or other known right angle drilled and riveted the two pieces together.
Step 2: Features
This aluminum square allows you to make straight lines up to 2 feet out with a circular saw using the first angle to clamp to the material and the second to guide the saw. If you liked this inscrutable please check out my channel GarageBot I promise I do more than pop rivet two pieces of aluminum.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    2 Discussions
    MountainMan63
    MountainMan63
    1 year ago on Step 2
    I am Not perfect by ANY MEANS, but just wanted to point out a couple grammatical errors.
    1. In your intro when you put (insructable) instead of "instructable".
    2. You did it again here in this sentence; "If you liked this inscrutable please". Best wishes!
    ScottM475
    ScottM475
    1 year ago
    I think if you flipped your aluminum angle so the leg faced away from your workpiece you wouldn't have to deal with the rivets possibly scraping the surface.
