Classroom Birthday Calendar
Introduction: Classroom Birthday Calendar
About: Hi my name is David, I like to make things out of Wood, also like to take things apart and fixed them.
Will it's that time of year when the children go back to School, and I wanted to make something School related. This is what I came up with, a Classroom Birthday Calendar.
You will need the following:
Cad/Cam program ( I used Vectric Aspire)
CNC Router ( I used the X-Carve CNC)
Lumber ( I used a piece of common lumber 23" x 7 1/4" x 3/4" )
Yellow Spray Paint
Red, Blue and Green Craft Paint
Small paint brushes
A can of Matte Clear finsh
2 Triangle hangers with screws
Drill with a 1/16" drill bit
small shoulder hooks
Key Tags
sandpaper
Step 1: Design
I design the sign in Vectric Aspire, I first set my dimensions of my board, then added lines for the ruler.
Added the wording Classroom Birthdays, added ABC and the Apple. I then created boxes for the Months and put the abbreviations of each of the months in the boxes.
I then switched to the toolpath side and done the following toolpaths.
Done a profile toolpath for the lines using a 1/8" ball nose bit
Done a pocket toolpath for the ABC, Classroom Birthdays and Apple
Done a profile toolpath on the Months
and the done a drill toolpath for the sholder hooks, just making a pilot hole
Step 2: Paint
I painted my board using Rustoluem Sun Yellow spray paint, I used a couple coats.
Now let this dry overnight.
Step 3: Carve
Place your piece into the CNC, and clamp down. I inserted a 1/8" Ballnose bit and began to carve.
Note I carved the whole sign with the 1/8" Ballnose bit
Step 4: Sand
Once the sign was carved, I went over the carve lines and lettering with a piece of sand paper to get rid of the fuzzies. Then blew off and wiped down before continuing.
Step 5: Clear Coat
I then sprayed a coat of Rustoluem Matte clear, also letting this dry overnight.
Step 6: Paint the Lettering
Then I used Craft paint to paint the lettering, trying to be careful and not getting any onto yellow.
Have a damp rag handy to wipe off if any gets on yellow, this will help in next step.
Step 7: Touchup
Well I had to lightly sand the top where I had gotten some of the Craft paint onto the yellow. I wiped off again and use some of the Yellow spray paint to touch up the yellow. I just sprayed a small amount into the lid and brush on.
If I had use the damp rag more, i might could have save some time on this.
Step 8: Install Shoulder Hooks
Take your drill with a 1/16" drill bit, and drill underneath each of the Months. Then screw in the shoulder hooks.
Step 9: Finish
Once your sign is finish, hang up and attached Key Tags, writing down each childs name on them.
This would be a great present or gift for a Grade School teacher, Thanks for checking out my Instructable
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
