Code a CustomCmd Script for Windows Command Prompt
Introduction: Code a CustomCmd Script for Windows Command Prompt
Do you use CMD a lot? I do! But a ton of people - including me - think it is much too boring. Today I will be coding a script that will allow us to customize CMD just enough to keep it fun. Let's get started!
CODE DOWNLOAD AT BOTTOM OF ARTICLE
YOU WILL NEED TO RUN THE FILE AS ADMIN
Teacher Notes
Step 1: Start Notepad++ (or Notepad)
First and foremost we need to start Notepad++. I use it to code everything! If you don't have it just open up Notepad. I would 100% recommend installing it.
Step 2: Code the Menu
Of course we will need to add @echo off and then I will just make a simple menu layout:
@echo off
REM By: Aidan Biggs REM AKA AT Vloggers REM REM Please do not claim this as your own. REM REM If you remove this it means you break the Code of Use found here: REM https://at-vloggers.weebly.com/code-of-use.html
title Custom CMD cls echo =============== echo By: Aidan Biggs echo AKA AT Vloggers echo. echo CustomCMD echo =============== echo. echo 1. REVERT TO NORMAL echo 2. CUSTOM echo 3. EXIT set /p rce= if %rce% == 1 goto revert if %rce% == 2 goto custom exit
Step 3: Add the Custom Tool
Next we will add the menu to set the custom parts of CMD. We also need to add the code that will update the registry and add our custom parts. We can also add an option to update one and not the other.
:custom
cls
echo What do you want the command bar, (look below) to say? echo type NONE to stay as is echo. echo Your-text-will-be-here^> echo. set /p cmdbar= echo. echo What do you want the window title to be? echo type NONE to stay as is echo. set /p cmdtitle=
echo Windows Registry Editor Version 5.00 >customCmd.reg echo. >>customCmd.reg echo [HKEY_CURRENT_USER\Software\Microsoft\Command Processor] >>customCmd.reg if "%cmdbar%" == "NONE" ( echo "Autorun"="title %cmdtitle%" >>customCmd.reg ) else ( echo "Autorun"="prompt %cmdbar%$G && title %cmdtitle%" >>customCmd.reg ) if "%cmdtitle%" == "NONE" ( echo "Autorun"="prompt %cmdbar%$G" >>customCmd.reg ) else ( echo "Autorun"="prompt %cmdbar%$G && title %cmdtitle%" >>customCmd.reg ) echo. >>customCmd.reg echo. >>customCmd.reg cls regedit /S %cd%\customCmd.reg del customCmd.reg cls echo DONE pause >nul exit
Step 4: Add the Revert Tool
Now that we have the actual custom part, we could leave it as is. The only problem would be that we would have no way to revert the changes. That is what this code is for:
:revert
cls echo Windows Registry Editor Version 5.00 >customCmd.reg echo. >>customCmd.reg echo [HKEY_CURRENT_USER\Software\Microsoft\Command Processor] >>customCmd.reg echo "Autorun"=- >>customCmd.reg echo. >>customCmd.reg echo. >>customCmd.reg cls regedit /S %cd%\customCmd.reg del customCmd.reg cls echo DONE pause >nul exit
Step 5: (OPTIONAL) Convert File to .exe
Go to Google and look for Advanced BAT to EXE. Download one and convert the file.
Step 6: DOWNLOADS
Batch (.bat) file and Executable (.exe) file:
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    3 Discussions
    at_vloggersYT
    at_vloggersYT
    1 year ago
    By the way, I didn't upload the .exe file because, when I tried, I got an internal server error
    HAVE FUN AND GIVE PROPER CREDIT: Aidan Biggs
    audreyobscura
    audreyobscura
    Reply 1 year ago
    If you put a .exe in a .zip archive you can upload it.
    at_vloggersYT
    at_vloggersYT
    Reply 1 year ago
    Thanks! (Sorry I'm new)
