Coffee-Antiqued Map
3,080
73
8
Introduction: Coffee-Antiqued Map
Coffee is the best dye for creating antique maps and documents. You won't believe how simple the process is, and how great your documents turn out!
Supplies:
  • 8x10 inch picture frame
  • computer
  • printer
  • instant coffee granules
  • microwave
  • oven
  • baking sheet
  • measuring cups
  • measuring spoons
  • paper cutter
Teacher Notes
Step 1: Printing the Map
Using a computer and printer, print a map onto an 8-1/2x 11 sheet of paper. (I printed a Lord of the Rings map.) Using a paper cutter, trim the paper down to 8x10 inches.
Step 2: Dyeing the Map
Heat 1/3 cup of water in a microwave. Add 2 tablespoons of instant coffee granules to the hot water. Stir until granules are dissolved. Place printed map onto baking sheet, and then pour coffee onto its surface. Using a spoon, carefully spread the coffee, to coat the entire surface of the map. Let it sit for 10 minutes, and then carefully remove map. Let the excess coffee drip onto the pan; pour excess coffee back into container, and then lay map back on the baking sheet.
Step 3: Baking the Map
Preheat oven to 205 degrees Fahrenheit. Place baking sheet on middle oven rack. Bake 5-10 minutes. After 5 minutes, remove, and check to see if it is done. The map is done when the edges are crisp.
Frame the map.
Coffee Speed Challenge
Third Prize in the
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
    8 Discussions
    jeanniel1
    jeanniel1
    7 days ago
    Ha ha! For my daughter's 8th birthday it was a pirate theme. So we made these big "treasure maps" then lightly coated them with a lemon (vinegar works too) wash, baked them in the oven for about 15 minutes once dry or until golden brown. So cool! Even tore the edges a bit to make it look really frayed and old.
    bludwig
    bludwig
    21 days ago
    Inkjet or laser printer?
    Aragorn9
    Aragorn9
    Reply 21 days ago
    Inkjet
    bludwig
    bludwig
    Reply 21 days ago
    I was always afraid the inkjet ink would get weird if was exposed to water after the fact. You've given me new confidence.
    rsucgang
    rsucgang
    21 days ago
    This is brilliant! thanks for making this instructable.
    Lorddrake
    Lorddrake
    21 days ago
    Nicely done .. i was going to make an entry for the coffee contest with the same idea ... you best me to it lol
    Best of luck
    Kink Jarfold
    Kink Jarfold
    23 days ago on Step 3
    I like the charred edges effect. I've got lots of antique paper on my desk, including a big part of the desk calendar. Yes, I'm a coffee spiller.....
    acheide
    acheide
    25 days ago
    Nice effect.
