Coffee Cutting Board
Introduction: Coffee Cutting Board
This is a epoxy cutting board with coffee beans in the middle.
Supplies:
Coffee beans
Wood for frame
Screws
Packing Tape
Casting epoxy resin
Teacher Notes
Step 1: The Cutting Board Frame
First I built a wooden frame the size I wanted the cutting board to be. Then I put packing tape around the edge and bottom of the frame, so the epoxy wouldn't stick when trying to remove from the frame.
Step 2: Mixing Epoxy With Coffee Beans
I put the coffee beans in the frame, then added the epoxy and hardener, mixed together as instructed by label. I mixed the coffee beans with epoxy till like soup and spread it evenly to dry.
Step 3: Last Step
Then after it dried I poured more epoxy resin over the first layer, and let it dry. After it dried I pulled frame off and sanded it as I wanted. I was thinking of having a handle, but decided I wanted it square.
Coffee Speed Challenge
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    audreyobscura
    audreyobscura
    5 weeks ago
    I didn't know that resin doesn't stick to packing tape, good to know!
