Recyclig Kitchen Oil -
Introduction: Recyclig Kitchen Oil -
Look around. Do you remember the last time you went to a restaurant? If it is so. Have you ever think about what happens to all that oil which has been used thta food?
Well, you should, because all oil used for the preparation not always is totally and completely absorved.
Teacher Notes
Step 1: What Are We Going to Do?
Have you ever think on what happens to all that oil which has been used that food? Well, you should, because all oil used for the preparation not always is totally and completely absorbed. The most part of the time people don’t know what to do with the oil, so they drop it in the sink and finally the oil ends in the ocean creating contamination and killing sea life. In order to, We think in create a soap based on cooking oil that will have a process of saponification. This process is the fusion of Sodium Hydroxide to became a solution amphipathic, in other words reacts with water like Hydrophilic and with other oils (to clean) like Hydrophobic. But now the question is: How can we do to recollect the oil? Well, the other part of project is change the routine to start recycling the oil in a special container (like trash) to can get it more fast.
The objective of this project, first It’s reduce de pollution in the ocean creating a soap to clean, but basically make a mental change in people. Specially in re use the oil but with a good motive and with this we are going to help a part of our planet.
Step 2: Your Materials
For this instructable you will need:
  • 200 g of Sodium hidroxide(pH 6.8 to 7.3)
  • 1 liter of used kitchen oil
  • aromatic essence
  • 2 liters o water
Step 3: Precautions
We must be careful at the moment of doing this hole process.
It is all about chemical reactions and how them change one sustance into another completely different.
The safety equipment that you will need is:
  1. Latex gloves: at the moment of the Sodium hidroxide with water interaction, it will release an exothermic reaction. You must be careful and not get to close to it.
  2. Lab goggles: For the same reason at the first point, we must avoid the gases generated for that thermical reaction.
  3. Plastic containers: For the soap and the Sodium hidroxide solution.
  4. Decorative containers: For the final result.
Step 4: Let's Start With This!
  1. Filter 1 liter of the recycled oil.
  2. Introduce 1 liter of water in a large plastic or stainless steel container.
  3. Add the caustic soda and stir until it dissolves in the water. You must take caution because the temperature will increase until reaching 80ºC and vapors that will be generated must not be inhaladed, they are toxic.
  4. Let it stand and cool to about 35 ° C and, if you want to add some essence, now will also be the time to do it.
  5. Slowly pour the used cooking oil over the water with the soda and stir the mixture constantly in the same direction (so that it does not cut), for about 30 or 40 minutes, until the mixture starts to thicken during the saponification process.
  6. Dump in molds and let the soap dry for about 30 days.
Step 5: Now... Time to Decorate!
After waiting for the solution to be solid, you will get ready for decorate your soap.
And that's it my friend! You have discover and use the power of the saponification process produced in by the reaction of the oil and the hidroxide.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
