Colors of Photons
211
5
4
Introduction: Colors of Photons
About: Just enjoy your life!
Colors of Photons
This painting change in each moment as new.
The things what i am used:
Adafruit NeoPixel Digital RGB LED Strip 144 LED×2
acrylic glass/ 1 cm thick
Adafruit Hook-up Wire Spool Set
Adafruit Perma-Proto Half-sized Breadboard PCB
Adafruit Rugged Metal On/Off Switch with Green LED Ring
Capacitor 1000 µF
Resistor 475 ohm
wood frame
Adafruit 5V 10A switching power supply
Anker 15600mAh Power Bank
Adafruit Pro Trinket - 5V 16MHz
Particle Photon
Adafruit Lithium Ion Polymer Battery - 3.7v 2500mAh
Adafruit USB LiIon/LiPoly charger
Android device Arduino UNO & Genuino UNO
photo foam board
Software apps and online services Spark Pixels android app.
Teacher Notes
Step 1: When Is Off and On
Step 2:
Step 3:
Colors of the Rainbow Contest
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    4 Discussions
    seamster
    seamster
    1 year ago
    These look amazing!
    If you wanted to add some text to explain your process of how you made these, that would be awesome. It looks like you've got plenty of photos of the process in step 2 - however, some additional written detail would be very helpful :)
    Jacsi
    Jacsi
    Reply 1 year ago
    Thank you very much for your point of view..i will add more info as well , be good:)
    saadland
    saadland
    1 year ago
    It is amazing painting! Unfortunately very poor at writing the instructuable... I am sure a lot people would like you to add more writing info about the whole making process.
    Jacsi
    Jacsi
    Reply 1 year ago
    well yes, i will add more description:) And thanks for the nice words.
