Combine Stun Baton V2
About: Rearranging Fermions
Heres the link to the V1 stun baton:
https://www.instructables.com/id/Combine-stun-baton/
Step 1:
First, as you know, buy a bug zapper and cut off the end with what ever preferred. After that cut two 22 inch long wires and solder them on to the the two wires sticking out of the fly zapper. Then find a pvc pipe thats about two cm thick and some flat mettle to support it. Run the wires through the pvc pipe before you attach the pvc pipe with duct tape.
Step 2: The Head (The Shocky Part)
Next take a bulk maple syrup bottle that you can get at most new seasons markets and poke a hole in the top.then place this over the top of the pvc pipe and run both wires through it. after that its up to you on how you situate the wires. i soldered two more wires onto the ones sticking out the top and ran them down the other side.
    • Faux-Real Contest
      Faux-Real Contest
    • Toys Contest
      Toys Contest
    • Epilog X Contest
      Epilog X Contest
    4 Discussions
    randofo
    8 years ago
    This project looks awesome but there isn't enough documentation of you actually making it to be a full Instructable. There are two things which you could do.
    1) If you happen to have images of you making your project you can create some more steps, add those additional photos into your Instructable and then republish your Instructable.
    2) If you don't have any more pictures of you working on your project, that's ok too. That just means that your project is better suited to be submitted as a slideshow. Your images are already in your library, and you can use the same text that you have already written for your Instructable so it should only take a few minutes to create your slideshow and show the world what you made!
    Thanks for your submission and let me know if you have any questions along the way.
    admin
    8 years ago
