Complete Shaving Set Holder
1,678
47
5
Introduction: Complete Shaving Set Holder
About: Too much wood, too little time.
I recently inherited my Grandfathers old razor, so I decided to invest in some real shaving supplies. However now I needed a place to put them.
Step 1: Sketch Time
First get an idea of what you want it to look like. I think walnut looks great with old fashion and vintage things so that's what I'll be using to make this.I found a block of wood which I then sectioned as seen above.
So as to not make the top too high I cut into the base and drew in a circle where my soap will sit.
Tips:
  • Measure your brush diameter
  • Length of brush
  • Soap dish diameter
Constrain everything within these three measurements.
Step 2: Put It Together
Stack them all up and if it looks good glue the three pieces together, we'll attach the base at the end.
Since circles were prominent in the design I used a cylindrical sander and belt sander to give my stand the curve it needed.
Step 3: Brush Holder
The most manually intensive part of the project will be this one if done by hand.
  • Drill out the red hole, make it smaller than the widest diameter of the brush.
  • Saw out the two blue lines
  • Sand and carve away until it's a snug fit.
Step 4: Soap Bowl and Blade Holder
Using progressively larger miter bits drill out the hole for the bowl
Once you're done with that I used a band saw and slowly carved out a ditch the size of my razor blade on the top.
Put everything together and admire your handiwork.
Step 5: Polish
Polish this bad boy with some polyurethane to make it waterproof and slicker than your grandpa in the 80's.
Be the First to Share
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    • Make it Move Contest 2020
    5 Discussions
    Kink Jarfold
    Kink Jarfold
    2 years ago on Step 5
    Dang, I must be old, too, because I remember shaving with this stuff. Your rendition of the holder is awesome! KJ
    raphan
    raphan
    Reply 2 years ago
    I'm still shaving with this stuff. I tried almost everything from 3, 4 blades and more, to Braun electric, rotational or high frequency vibrations razors and I always returned back to the old almost perfect system !
    Peaches and Plums
    Peaches and Plums
    Reply 2 years ago
    Yeah I really like the way it shaves so I thought i may as well get the whole set and keep using it. I'm happy you guys like it.
    raphan
    raphan
    2 years ago
    Beautiful !
