Computer External Cooler
Introduction: Computer External Cooler
The idea of this project came when I was playing Far Cry 5 on my computer when I took off my head phones to hear the roar of the fans cooling the computer I felt behind the computer and was shocked at how incredibly hot the computer and the area behind it was, at this point hot air was sitting behind the computer I thought of how I could make the air move out from behind the computer while not making to much noise. So I came up with a plan to more or less trap the air in a box behind the computer and have it be expelled by a single fan that is held in the computer. The picture (shown above) shows the computer with the creation behind it, normally the box would be upside down.
Step 1: The Design
The design was pretty simple, in order to have the box securely fit to the back of the computer I made a 17 x 2.5in square shaped gap in the back of the box in order to have the computer interlock with the box, I got the measurement by measuring the computers protruded part which could be considered a downside to this computer but a plus side in this case. (computer shown above) I made the part file with various holes in the side of the box to provide air flow out the sides and some style points.
Step 2: Assembly
As for assembly I used wood glue to secure the various pieces of wood together, however if I was to do this again I would make interlocking tabs to make it a little easier to put together. The fan was put on with screws that would secure it to the wood (which was found to be a very difficult task). If you are making the cad file for the side pieces make a larger hole which you can use to feed the cord through to power this fan. You can also make a hole in the back for the cord if you are worried about aesthetics, but if ou are putting this behind your computer you are clearly not worried about aesthetics.
Step 3: Test
I assembled the box and attached the computer loosely to it and played another round of Far Cry, The box got very hot and radiated a "campfire smell" around the room, however did the job that it was supposed to which was keeping air from sitting behind the computer, If I was to do this again I would use better fans because the wimpy fan that I used. Not that I was worried about it looking bad but the wood did not look great up against the metal and black of the computer. RGB fans would be cool too.
Woodworking Contest
Woodworking Contest
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    seamster
    seamster
    2 years ago
    Interesting solution, thanks for sharing!
