Concrete Drink Caddy
1,123
18
7
The inspiration for this project originated from the idea of using concrete's thermal properties to create a beverage cooler. Concrete has low thermal conductivity. So if a beverage cooler were able to be chilled along with the beverages before transporting, the beverage cooler would resist the temperature change and act similarly to an ice pack. Realizing that concrete is not a light material a standard box-style cooler would not be practical, so a beverage caddy style was used instead.
This Instructable will focus on the concrete portion of the caddy and assume you are capable of creating the wooden frame for the caddy. Drawings for the wood frame are attached for reference.
Supplies:
3/4in plywood
stain
concrete mix with no aggregate
mixing cups
water
cans/mold voids
Teacher Notes
Step 1: Wooden Frame
Cut and assemble drink caddy frame per “DRINK CADDIE FRAME” drawing (ATTACHED)
Step 2: Stain/Seal Wooden Frame
Stain/paint/finish drink caddy frame to your desired appearance.
Recommended: Oil or polyurethane topcoat to help mitigate water from concrete from soaking into the wood.
Step 3: Prepare Mold Voids
Evenly space 3 LARGE “.99cent ICED TEA” cans on each side of the drink caddy frame and screw or hot glue in place. Cans should measure close to 2.86” in diameter.
Step 4: Prepare Mold Walls
Attach “form walls” to the caddy so that the top of the walls measure 5in. from the top surface of the base.
Step 5: Mixing and Pouring Concrete
Measure out approximately 15 cups of aggregate-free concrete mix (sift out the aggregate if necessary). Add water until a honey/cake batter consistency is achieved. A more runny consistency, than typical concrete, is needed to fill the small spaces without the need for packing. For a more rough appearance, make less runny. Pour mix into form.
Step 6: Remove Form
After 24 hours to set, remove the form walls and cans.
Step 7: Finishing Touches
Shape/round all sharp/flaking edges of concrete with a metal file and clean any surfaces of unwanted concrete overspill.
Stone Concrete and Cement Contest
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    7 Discussions
    Hairy Bear
    Question 13 days ago on Introduction
    Too heavy, why not just cut holes in Styrene foam sheets?
    Ev
    15 days ago
    Use some styrofoam beads or pumice chunks to make it less heavy?
    RobertN1Penolopy Bulnick
    Reply 15 days ago
    Yes, once you load it up with six beverages it becomes quite heavy. This is more of a novelty and not intended for long trips. Maybe just a trip from the beach house to the beach. I have not weighed it loaded but I'd guess upwards of 15 lbs.
    RobertN1yrralguthrie
    Reply 15 days ago
    I did not run this through the scientific method and do a comparison so I honestly don't know. This is more of a novelty item. It will keep your drinks cool but likely not as long as an insulating foam cooler since they are sealed with a lid. This caddy has an open top and will be likely become room temp much quicker.
