Concrete Repair With Hot Glue
About: Professionally I have been a summer camp counselor, a Draftsman/designer, salesperson, bicycle mechanic, laminate flooring machine mechanic, teacher, and designer of the OP Loftbed. Personally I am a human...
When we moved into our current house, (almost six years ago) I noticed cracks in the concrete driveway. Not just expansion joints, but cracks and a few small holes. I got to reading how water can freeze and plants can grow in the cracks and make them bigger. If these cracks and holes are not maintained properly, it can result in irreversible damage. I originally used a special silicone caulk made for sealing concrete and masonry. It worked but, after a year, it started coming out of the cracks. The caulk cost about ten dollars a tube and I thought I would try hot glue instead. The hot glue has held up over two years. In this Instructable I will show you how I use hot glue on the expansion joints, cracks, and small holes in my concrete driveway.
Step 1: Tools and Materials
You only need a few tools for this job. A hot glue gun with hot glue sticks. A screwdriver or something strong to scrape dirt and plants out of the cracks. An old tooth brush or steel wire brush are useful for getting the cracks and holes clean. You should wear safety glasses and gloves.
Step 2: Scrape Out the Dirt and Plants
Use the screwdriver to scrape the dirt and plants out of the cracks. You could spray water in the crack to get it really clean, just let it dry before applying the glue.
Step 3: Use the Hot Glue Gun
Once your crack is clean, use the hot glue gun to apply a bead into the crack. You want the glue to fill the crack to the top. The goal is to keep dirt and water out of the crack.
Step 4: Small Holes
The hot glue can also be used to fill small holes.
Step 5: Prepair the Hole
An old toothbrush or wire brush will help with scrubbing out the dirt from small holes.
Step 6: Fill the Hole
Fill the hole just like the cracks. If your hole is larger, you can put some small gravel in the hole before applying the hot glue.
Step 7: Video.
I also made a video.
Thanks for watching.
    • Comfort Food Challenge
    • Faux-Real Contest
      Faux-Real Contest
    • Toys Contest
      Toys Contest
    3 Discussions
    BriFibrochic
    6 months ago on Introduction
    Thank you for this, finally something I can do about those damn cracks! You saved me from buying stuff that just doesn't last, have you found anything else that works as good as the hot glue?
    BetsyFartBlossom
    6 months ago
    Oh, definitely going to try this! What do I have to lose, except face when the neighbours see me doing this:) Just as an aside, I have a statue that has some cracks and pieces that have fallen off and am going to try to hot glue them too. Probably won't work, but who knows? Gotta try something:) Thanks for this, I voted for you.
    Thanks for the comment and the vote. Good luck with the statue, I think hot glue will have no problem with the cracks, but you might need some type of epoxy to glue the pieces back on. Let me know how it turns out.
