Connect 2.4" TFT LCD to Arduino Leonardo Micro
Introduction: Connect 2.4" TFT LCD to Arduino Leonardo Micro
I bought these cheap TFT LCD from Ebay, with also cheap Arduino Leonardo Micro.
I had some trouble to make them work, finally got it.
Teacher Notes
Step 1: Libraries
You will need the Smoke and Wires Library :
https://github.com/Smoke-And-Wires/TFT-Shield-Exam...
You also need the GFX library from Adafruit :
https://github.com/adafruit/Adafruit-GFX-Library
Add the line #include "LeoMicro.h" in SWTFT.cpp and comment out the other included originally for Uno or Mega board.
Put the LeoMicro.h file in the library folder.
Step 2: Pin Connection
The new pin configuration is as follow :
LCD Data Bit :    7    6    5    4    3    2    1    0<br>port/pin :  	PD7  PB6  PB5  PD4  PD3  PD2  PD1  PD0<br>LeoMicro      	  6   10    9    4  Txd  Rxd    2    3
Connect LCD_RST to pin 14.
The other pins stay the same :
LCD_RD to A0
LCD_WR to A1
LCD_CD (LCD_RS) to A2
LCD_CS to A3
The modifications were made to the write8inline and read definitions inside the LeoMicro.h file.
Step 3:
Step 4: Example Sketch
The file graphicstest.ino was from Smoke and Wires, I simply deleted the redefinitions for the A0-A3 and Reset pins.
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
