Convert an Old Bed Into a Bench Seat
790
12
8
In this instructable I'm going to make a bench seat from an old bed.
Supplies:
Bed
Drill
Grinder
Staple gun
Pocket hole jig
Drill
Screws
Screwdriver
Glue
Teacher Notes
Step 1: Watch the Build Video 😁😁
Step 2: Cut the Footboard in Half (ironwork)
After removing the iron work from the footboard I used a reciprocating saw and grinder to cut it in half.
You could use just 1 of those tools.
Step 3: Cut the Footboard in Half (timber)
After removing the legs from the foot board I cut the top round rail in half. I then reattached each half to each leg with glue and screws.
I left the bottom rail in one piece to use as a stretcher on the front of the bench.
Step 4: Attach the Bench Sides to the Headboard
I first found the height of the sides of the bench and marked that out on the headboard.
I pre-drilled 2 holes and countersunk those holes on the back of the headboard.
Using a clamp to hold the leg and headboard together I screwed and glued from the back of the headboard.
Step 5: Attach Front Stretcher
Using a pocket hole jig a made 3 pocket holes on each end of the stretcher.
As I didn't have a clamp long enough I used a ratchet strap to hold the stretcher in place while I glue and Screwed it in place.
Step 6: Make Stretchers for the Bench Sides.
Because i used the foot board stretcher for the front of the bench I needed to make new stretches for the sides out of two-by-fours.
I ran some two-by-fours that I had laying around through my thicknesser to clean them up, cut them to length and attached them with glue and pocket holes.
Step 7: Attach Ironwork to Bench Sides
Now that i had the frame of the bench made I could reattach the ironwork to the sides.
I do this by drilling two holes in each side of the iron work and screw it in place
Step 8: Make Seat Base
After cutting two strips of 2 x 4 on my table saw a pre drilled and Screwed them to the bench frame to make seat rails.
Step 9: Fill the Screw Holes
I filled all of the screw holes with dowels.
once the glue is dry cut them to length and sand them flush.
Step 10: Touch-up Dowels and Scratches
I went around the entire bench touching up any scratches and the dowels with stain.
Step 11: Seat Cushion
Using a scrap of MDF from a previous project as a base I cut a piece of foam to fit.
I used hot glue to hold the foam in place while I attached the fabric with a staple gun.
And Screwed the seat cushion to the bench.
Step 12: Paint Ironwork
Last step was to go over all the iron work with an outdoor metal paint.
The paint are used is made for outdoor fences.
First Time Author Contest
This is an entry in the
Be the First to Share
    • Furniture Contest
      Furniture Contest
    • Reuse Contest
      Reuse Contest
    • Hot Glue Speed Challenge
    8 Discussions
    seamster
    5 days ago
    Nicely done! Using the footboard as you did is a brilliant idea. Great work!
