Cool, Efficient, Mag-lite
47,952
55
74
Introduction: Cool, Efficient, Mag-lite
Replace the bulb in a 2xAA mag-lite with a bright white led. A cool burning led will give you longer battery life and won't burn your face off.
Teacher Notes
Step 1: Collect the Parts
You'll need a 3.2 volt LED -- I think most bright white LEDs qualify. A ruler or caliper. An old, beat-up mag-lite, the kind that takes 2 AA batteries. Some wire cutters. A low speed or variable speed drill and 1/4" bit (not pictured). A small vice or pair of adjustable, locking (vice-grip style) pliers will come in handy (not pictured).
Step 2: Disassemble the Head of the Flashlight
My old mag-lite was already missing the bulb. Unscrew the front part of the head to gain access to the parabolic mirror.
Step 3: Drill Out the Hole in the Plastic Mirror
Place the plastic mirror carefully in a vice, hold it with a pair of slip-joint or vice-grip pliers... or if you have the hands of an oil-rig worker, with your fingers. Slowly drill out the center hole of the mirror with a 1/4" drill bit. This will allow the mirror to fit over the LED.
Step 4: Trim the LED Leads
Trim the LED leads to 1cm, .4 inches, or 3/8". You could probably go a little shorter to put the LED closer to the focus of the mirror, but this spreads out the beam the way I wanted it.
Step 5: Discard Mag-lite Bulb and Install LED
Wiggle the LED around until you can insert the leads into the two small holes that used to hold the mag-lite bulb leads. The LED should light up if the batteries are installed. If not, flip the LED around. Remember, this model of mag-lite is turned on by unscrewing the head of the flashlight.
Step 6: Screw the Head Back on the Flashlight
All done!
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
    74 Discussions
    botronics
    botronics
    7 years ago on Step 5
    The only rechargeable 1.5 batteries are the rechargeable alkaline type. Nicad and NiMH are 1.2 volts (1.37v hot off the charger) and never 1.5 volts. If you have a rechargeable Nicad or NiMH marked "1.5v" show me a photo. I don't like the rechargeable alkaline because they leak.
    COMMODORE64
    COMMODORE64
    Reply 7 years ago on Step 5
    that comment was retarded made at 4 years ago and we all knows im wrong about rechargable 1.5vs
    come on shut your yap and move on!
    botronics
    botronics
    13 years ago on Step 5
    No current limiting resistor? How long has it been burning? Does it work with rechargables?
    COMMODORE64
    COMMODORE64
    Reply 12 years ago on Step 5
    It says 2AA battery equal as 3V, and this LED is 3.2V, so nothing is bad. And yes, rechargable works too, because they works as 1.5V each.
    PerfectPantaloons
    PerfectPantaloons
    Reply 9 years ago on Step 5
    every AA battery i have ever used was 1.5 V...
    JamesRPatrick
    JamesRPatrick
    Rechargeable batteries are only generally 1.2V unless they say otherwise.
    PerfectPantaloons
    PerfectPantaloons
    i don't know i'm looking at my collection of batteries... (and i have a TON of AA's) and they all say that they are 1.5.... including the rechargeable ones.... what brand are you talking about???
    ttaylor10
    ttaylor10
    All my rechargable AA's say 1.2 V
    Just my 2 cents.. Where did you get rechargables that are 1.5?
    JamesRPatrick
    JamesRPatrick
    Rayovac, Radioshack, Sanyo, and a couple more generic Chinese brands that I have. If yours are newer and 1.5V, that's great, more compatability. But as of a few years ago when I bought my last ones, the standard seems to be 1.2V for rechargeable AA's.
    PerfectPantaloons
    PerfectPantaloons
    hmmm well then this is all news to me... this will be very helpful to me and my projects.... Thanks for the info
    COMMODORE64
    COMMODORE64
    Reply 11 years ago on Introduction
    Sorry, You are right. Thanks for the correction.
    severepb
    severepb
    actually, 2 AA batteries brand new are about 1.6 to 1.7 v.
    Prometheus
    Prometheus
    13 years ago on Step 6
    light output might actually be greater than the maglite bulb, depends on the led's mcd. If you find a "superbrite: white, the LED will make a laughingstock of the old bulb. Alternative to drilling out the focus (reflector), you can find the same ratings for ini's and sub-mini's that will fit without any modification except to the LED lead length. You will know a superbrite if it's hard to tolerate it shining directly into your eye, and perhaps leaves a bit of retinal burn.
    phenoptix
    phenoptix
    Reply 13 years ago on Step 6
    That's not the best way to test LEDs!!
    Pwag
    Pwag
    These guys are right, use someone else's eyes.
    phenoptix
    phenoptix
    6 years for a reply to that comment Pwag! But it was worth it!!!
    Pwag
    Pwag
    Ha! The internet is full of surprises some times!
    Eirinn
    Eirinn
    Pointing superbrite LEDs at your eyes can cause retina damage it's a very bad way to do it :)
    Guardians38
    Guardians38
    10 years ago on Introduction
    I have GOT to make this... im going to buy a flash light just for this =)
