Cool Celestial Cubes: a 3d Puzzle
108
Introduction: Cool Celestial Cubes: a 3d Puzzle
My friend and I needed to make a kinetic art project for our AP Physics class, and we wanted to do a 3d puzzle. Since the 50 year anniversary of the moon landing is this year, we decided to make it space themed.
Supplies:
1) Enough paper to make four of the paintings in the size you want. We made ours 45cm x 112.5cm because we were putting them on the sides of cubes that were 7.5cm on all sides. Our final puzzle was 6 cubes by 15.
2) Painting supplies
3) String
4) Hot glue
5) Cubes. We made ours out of styrofoam by cutting up large pieces with a saw. Our cubes were 7.5cm on all sides.
6) Something to suspend your puzzle from. If you had a strong ceiling, you could use that. We used an old clothes rack.
7) A way to cut up your paintings. We used an exacto knife and scissors.
8) Weights to hang on the strings to weigh them down.
Step 1: Paint
These will be the paintings that hang on all four sides of the puzzle. We made ours 45cm x 112.5cm.
Step 2: Cut
Now you need to cut the paintings into 7.5cm x 7.5cm squares, so you can put them on the sides of the cubes. We made a grid on the back of the paintings, and used an exacto knife and a meter stick to cut each column, then we cut the rest with scissors.
Step 3: Thread the String Through the Cubes
We used a wooden dowel to make a hole in the middle of the cubes, then we used the back of the dowel to push the string through it. We made 6 strings of cubes, each with 15 individual cubes on them.
Step 4: Attach the Painting
Now you need to attach all the pieces of the painting to the sides of the cubes. We used hot glue for ours, and it worked well.
Step 5: This Is What All Four Sides of the Cubes Looked Like After Gluing Them
Step 6: Hang the Cubes
Now you can hang the finsished pieces wherever you are hanging them. We added 200g weights under each column of cubes to keep them from moving a lot.
Step 7: Now You're Done!
Set this puzzle up and have fun trying to solve it!
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
