Cordless Drill Charging Tool Wall and Storage Rack
2,130
48
About: Hi I'm Linn and on my Youtube Channel I have lots of great videos about building, construction and fun projects. You can also check out my site @ http://darbinorvar.com
I wanted to create an organized wall system for my various cordless power tools and a way to charge and store the batteries. The result? Deep shelves in the bottom unit, a "counter", a cubby hole section, pistol grips and a wooden wall that can be used to hold different tools. For the complete process of this build, make sure to watch the video that goes overall the steps.
Teacher Notes
Step 1: Cut the Pieces to Size
I began with cutting up the plywood to size. For this build I'm using 3/4 inch plywood for all the sections.
If you'd like more precise directions of the process. then you can download this free plan of this build.
I simply used a circular saw and a miter saw for all my cuts, so it's certainly possible to build this tool wall using limited tools.
Step 2: Assemble the Base
First up, the base. I began with creating a basic box, using screws to assemble.
Then I added a nailing strip, and positioned the middle shelf by placing the divider on the sides while screwing in. Finally I attached the divider in the middle. For the top section, I used pocket holes, since I wasn't able to reach it from the underside.
Once the base was assembled, I attached the unit to the wall by screwing through the nailing strip into the studs. I positioned the unit on top of the foundation in my garage, so it's a little bit off the ground.
Step 3: The Cubby Unit
Once the base unit was constructed, I assembled the pieces for the cubby section, again using screws for assembly. The top shelf is a little wider than the remaining cubbies, so it can be used as a deeper shelf.
Step 4: Attach the Backing
To secure the cubby unit to the wall, I first secured the back section for the middle to the sides of the cubbies using pocket screws. Then the back piece functioned as a large nailing strip which I attached to the wall into the studs.
Step 5: Pistol Grip
I painted the base and the top unit, and moved on to create the pistol grips. I wanted this unit to be able to hold a variety of drills as well as nailing gun, glue gun and other similar tools.
I attached plywood pieces together with glue and then nail gun, altogether I made 6 plywood sections, that I attached to a board to create the pistol grips. Once all the pieces were attached, I went back and secured everything with screws.
Step 6: Back Wall
To create some more contrast and visual interest, I decided to cut up some thin strips of wood to nail to the back piece of the wall. At first I had stained the plywood, but I didn't think it looked that great, so instead I nailed on the wood strips, which turned out pretty neat.
Step 7: Extra Storage & Finishing Touches
To create extra storage, I added some plastic VersaTrack hooks to the sides of the unit, so I could add hooks and store extension cords, compressor hoses etc... I added a lighting strip around the whole unit for some additional light and then attached battery chargers to the sides before addition a variety of tools.
Step 8: Conclusion - Watch the Video
For a much better perspective, make sure the check out the video that goes over all the steps of this build in more detail!
Step 9:
    • Indoor Lighting Contest
    • Metal Contest
      Metal Contest
    • Make It Fly Challenge
    audreyobscura
    5 months ago
    This is awesome! You should enter this into the Organization Contest!
