Cozy Felt Radiator Chair
Introduction: Cozy Felt Radiator Chair
About: I like to make things. Art, inventions, tools, ukuleles, etc...
In the winter people like to sit on radiators because they're toasty and warm. This chair enables comfortable sitting while reading or watching TV. It's in two parts which are shaped to lock onto the radiator. This allows different seating angles and spacing.
Supplies:
Scrap wood or plywood.
½" felt
wood glue
nails or screws
contact cement
varnish
Teacher Notes
Step 1: Gather Some Wood
I had some pieces of 3/4" oak left over from another project. The back piece is 22"x7". The seat is 11"wide x 9"deep. The riser piece is 4 ½"high. You will probably want to resize depending on your radiator and whatever you're leaning the back against.
Step 2: Cut the Pieces
The most important part is the round cut-out that allows the boards to lock onto the radiator. Mine is about a 3" diameter arc. Cut this with a hole saw, bandsaw, jigsaw... whatever you have. Test fit the pieces on the radiator. Some shaping with a round rasp or file will probably be needed to get a good fit.
Step 3: Glue Up the Seat
Wood glue and screws or nails should hold it together.
Step 4: Add the Felt
I used contact cement which is very smelly, but holds well. Apply it to both sides. Allow to dry. THEN stick the pieces together. Alternately you could tack the felt on without the glue.
Step 5: Sit. Enjoy.
Furniture Contest
Furniture Contest
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
    3 Discussions
    Meglymoo87
    Meglymoo87
    6 weeks ago
    Inventive! Good job :D
    Alex in NZ
    Alex in NZ
    6 weeks ago
    This is just fantastic! The number of hours I spent sitting on a radiator like that to read when I could have been sitting on a chair! Well done and thank you for sharing your imagination :-)
    Gadisha
    Gadisha
    6 weeks ago
    Nice idea
