Cozy Neck Warmer
Introduction: Cozy Neck Warmer
Make this easy Cozy Neck Warmer in an hour or two using basic machine sewing skills. I used Minky fabric but it could be made with Faux Fur, Fleece or flannel depending on your style, preference or cozy requirements.
Supplies:
Tape Measure
Scissors
Fabric such as Minky, Fleece, Faux Fur, or Flannel
Straight Pins
Sewing Machine
Thread
Hand Sewing Needle
Teacher Notes
Step 1: Cut Your Fabric
Using scissors cut 2 pieces of fabric 36x5 inches.
Cut 1 piece of fabric 6x5 inches.
If you want a longer neck warmer increase the 36 inches by desired amount. If you want a wider neck warmer, increase the 5 inches by desired amount.
I used a 1/2 inch seam allowance in all sewing.
Step 2: Prepare Your Loop
start with the 6x5 piece of fabric that you cut.
Fold and pin edges of the longer sides toward the wrong side of the fabric. Sew them down. This is just so the fabric does not fray. If you are using fleece or faux fur you can skip this since they will not fray.
Fold right sides together and sew along edge to form a tube.
Turn the tube right side out.
You now have a small tube with edges turned and sewn under.
Step 3: Attach Tube to Scarf Body to Form Loop
Pin the tube you just created to the right side of one of your 36x5 strips. I pinned mine 4 inches from the bottom edge and centered it across the width.
Sew the two short edges in place where you pinned them. This has now created a loop.
Step 4: Sew Back and Front Together
Lay the piece with loop face up on your table. Place your other 36x5 piece without loop, face down on top of it.
Your two pieces should be right sides together with the loop on the inside. After sewing, we will turn it right side out.
Pin your 2 pieces together. Leave a 4 inch opening in the center. I usually mark the opening either with double pins or different colored pins so I don’t sew it completely closed.
Sew around, using a 1/2 inch seam allowance.
Step 5: Clip and Turn
Carefully clip across the corners to remove excess fabric. Do not clip into your stitching.
Reach through the 4 inch opening and turn your neck warmer right side out.
Fold edges of opening under and use a hand sewing needle to stitch the 4 inch turning opening closed. This will be behind your neck so if your sewing skills are lacking no one will notice!
Step 6: Loop Your Long End Through the Loop
Put neck warmer around your neck with the sewn on loop facing your chest. Place the long end through the loop and snug it up tight with one end over your shoulder or looser and leave the “tails” hanging in the front.
It looks great on its own or under a jacket.
Enjoy your Cozy Neck Warmer and make one for all of your friends and family members.
Warm and Fuzzy Challenge
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    2 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    5 weeks ago
    That looks so soft and comfortable :)
    MLytle
    MLytle
    Reply 5 weeks ago
    Thank you! It’s my first project on Instructables!
