Cpt America Shield
383
5
4
Introduction: Cpt America Shield
Before we get started, does anyone want to get out?
Okay, so I just want a badass wall decor so I made a/the Captain America Shield.
I tried to make it as simple as possible thats why it is not perfect..but still enough cool.. I mean in the geek world.
Teacher Notes
Step 1: The Materials
The main important thing is the base, so the body of the shield.
Im checkhed many many option...parabola antenna dish, fiber glass, foam, snow sled, but finally I found an iron grill plate with the perfect shape. The leg and handle remove was the only necesarry modification.
Step 2: Bodywork
For the nice surface I needed to grinding the whole shield. That was a long and hard part but it is necessary for the steel look.
Step 3: Painting
To make the plan for the star and circles I had to made an unique calipers, so I just drill 3 pen-size hole into a wood piece with the perfect distance and drew the template.
According to the template, masked the different part..and then in the last step I just paint everything for the right color.
I like the battle damaged look so I put on some shot mark as well.
Step 4: The Result
Finally I just cleaned the whole shield and put it on the wall with a small data table.
I know it is not perfect and a bit hand made look but actually not bad and I liked to make.:-)
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Fix It Contest
      Fix It Contest
    4 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    The burn marks from the bullets is a great touch :)
    airhogs
    airhogs
    Reply 1 year ago
    Thanks! I like the battle damaged style:-)
    Jaymarbs
    Jaymarbs
    Question 1 year ago on Step 4
    What info did you put on the data plate?
    airhogs
    airhogs
    Answer 1 year ago
    Just some main data (check on the attached picture). The control no. is the date when I finished the shield, (with my name monogram) and the Serial no is the date when I saw the Civil War
