Create a Circular Landscape Using Digital Manipulation
Introduction: Create a Circular Landscape Using Digital Manipulation
About: I am an Art and Photography teacher currently based in Dubai. Previously I have worked in Hong Kong and the UK.
Today we will be experimenting with filters on Pixlr.com to create circular landscapes.
This is not a very complicated technique, but it does have a few steps which you need to follow to ensure the best possible results.
If you do not have your own landscapes, you can use a website like Pexels.com to search for stock landscape images to experiment with.
If you struggle to follow the guide, please have a look at this video to support your own experimentation.
Good luck and for similar instructables, be sure to have a look at my profile and YouTube Page: Mr Art and Photography!
Step 1: Step 1: Open Your Landscape Image on Pixlr.com
Either using your own image, or one found from online, go to Pixlr.com and open your image.
Step 2: Step 2: Turning the Image Into a Square
Firstly, Go to Image -> Image size and make sure 'Constrain Proportions' is not checked.
Secondly, Match the lowest number value. In the example I change the width to '1500' to match the height.
This will change your image into a square image shape.
Step 3: Step 3: Rotate the Image
Go to Edit -> Free Transform and turn the image upside down.
OR
Go to Image -> Rotate Canvas 180 and turn the image upside down.
Tip: If you hold shift whilst rotating the image using Free Transform it will move the image in increments, making it easier to turn the image upside down.
Step 4: Step 4: Apply the Filter
Go to Filter -> Polar Coordinates to complete the image manipulation.
When prompted you can experiment with the transformation. To achieve a similar effect to my examples I have used React to Polar from the drop down selection.
Good luck with your own digital manipulations!
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Halloween Contest
      Halloween Contest
