Creative Skateboard Modelskateboard Model
Introduction
Double up skateboarding is a very flexible skateboard has tail and single become warped board separately, but whether he slip or are all the same there anyway this also reflected the double up skateboarding the flexibility of a lot of people say double up skateboarding is the true than drab skateboards, skateboard double up skateboarding can support some more flexible movement over time, single become warped skateboard gradually decline, and double up skateboarding gradually popular also, today I introduce is double up skateboardi
I used takercad, and the design idea is to design colorful wheels to have a better experience when sliding
Teacher Notes
Step 1: Build the Board
Build the board and the upturned
part of the skateboard
200×560×10
The following dimensions
are in mm Make two cylinders of the same size with a diameter of 202 and a height of 10. Align them and rotate the cylinder appropriately so that the highest point of the cylinder is 35 away from the cuboid. Cut and merge the redundant parts with hollow cuboid
Step 2: Make the Screws
The three parts of the screw make up a cylinder
(all the dimensions below are in mm)10, 10, 2 as the base plate, the cylinder of the upper part is 5, 5, 10.77, and the cone size is 5, 5, 3.23, forming a single screw The overall adjustment is 15mm high and the color is white
Arrange the eight screws and arrange them
First row, second
row screw distance for 55 adjustment into the integral part of the white integral height adjustment for 20 mm high
Step 3: Wheel Design Options for Metric Gear 20 Mm Radius
1 Three wheel design options for metric gear
20 mm radius
2 The pulley is a ring with an outer diameter of 55 and an
inner diameter of 50. The length and width of the white part are selected as 50. A hole with a diameter of 20 is made inside
3 As you can see, the wheel is made up of three
colors and the center of the wheel is cut through the hollow body, each part with a central Angle of 120 degrees
4 Elongate to 142 mm long
5 Copy and align the wheels and merge them
Step 4: Now Proceed With Preliminary Assembly
1 As can be seen from the figure above, I
added two bottom plates with a size of 60, 70 and 2, which act as a fixation
2 Add roof shape size 60 60 20
3 The wheels are copied and adjusted to merge
with the main body
4 Two fixed devices were added The dimensions as above are combined for a
height of 45
Step 5: Now the Skateboard Has Been Basically Made
Now the skateboard has been basically made
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
