Credit Card Holder on Tinkercad
33
Introduction: Credit Card Holder on Tinkercad
This is how to make a credit card holder using Tinkercad.
The link is here: https://www.tinkercad.com/
Supplies:
You need:
1. Internet access
2. Tinkercad
Teacher Notes
Step 1:
Get a box out and resize it to a certain size. I resized it to 25 mm by 40 mm by 5 mm.
Step 2:
Get a box hole and a cylinder hole out.
Step 3:
Resize the cylinder hole to 5 mm by 5 mm or less, and align to the middle of the solid box.
Step 4:
With the box hole, resize the thickness to about 1 mm and raise it so it will be approximately in the center in height of the solid box.
Step 5:
Put the box hole in the solid box, put half widthwise in the solid box, and resize the length so it's bigger than the solid box.
Step 6:
Make any adjustments to the pieces before grouping. I resized the cylinder hole widthwise to 7.5 mm. Then group. Then resize if you want. I resized it lengthwise to 50 mm.
Step 7:
If red is not what you're going for, change the color. I changed the color to black.
First Time Author Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
    audreyobscura
    audreyobscura
    7 weeks ago
    Thanks for sharing your design tips in Tinkercad!
