Credit Card Size Phone Holder
Introduction: Credit Card Size Phone Holder
I designed this two part phone holder as exactly credit card size. Only a little bit thicker (2mm). You could carry in your wallet all time.
Step 1:
Just you need to print it
Step 2:
If parts are too tight (cause of printing quality) you can use correct file for your printer tolerance.
Step 3:
Easy to use also helps in cable organization.
Step 4:
If you don't have 3d printer, you can cut any 2mm plate (acrylic, plywood, ect.) with laser cutting machine or cnc milling machine.
Step 5:
...or, If you have precision hand you can take ordinary print of this .pdf file and cut the plate with fret saw.
Pocket Sized Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    This is a great little print! What did you use to design it?
