Credit Card Sized Contactless Voltage Detector (555)
Introduction: Credit Card Sized Contactless Voltage Detector (555)
The idea came looking at other Instructable:
https://www.instructables.com/id/Contactless-Volta...
I have chose the design with the 555 because I had several 555 around and I like build small projects, like this other credit card sized project.
https://www.instructables.com/id/Credit-Card-Sized...
Teacher Notes
Step 1: The Circuit and Components
This is a screenshot from the project of :
https://www.instructables.com/member/Tarantula3/
The Component are:
  • 555 Timer
  • Credit card
  • battery holders (recycled)
  • 2032 coin batteries
  • 10 kΩ resistor
  • 220 Ω resistor
  • 4,7 μF electrolytic capacitor
  • buzzer
  • led
  • switch
  • copper tape (antenna)
  • epoxidic glue (few drops)
Tools:
  • solder
  • cutter
Step 2: First Prototype
As you can see in the photo, pretty ugly.
But it was working, so I started to work to the final version.
Step 3: Final Version
As you can see in the video it is working and with good sensitivity, actually I had to keep the antenna very short due to the high sensitivity.
I used a 1kΩ resistor instead of 220Ωto reduce the sound of the buzzer .
Pocket Sized Contest
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
